Thread: I Think My Axles are Going ?
09-30-2009, 06:17 PM #1
I`m not shure if this is a normal sound but , with my car on level ground I was messing around one day and decided to give my rear wheels a shake with my hands & I can hear a clunk noise and can feel alittle play when moving the wheels in & out ?
Both sides do it but more so with the right side , could it be an axle going ?
I do notice some noise on the highway too & it`s not the aircraft turbine sound I`m allready hearing . Car is an Auto and also cluncks a little in the rear when it shifts , if thats any help ??
Thanks .1999 T/A FIREHAWK - SLP Lid & Bellow,LT`s & Catted Y & Power-Flo Catback , MSD & NGK , UMI 3P SFC,ADJ PHB,STB,LCA`s & Relos , Eibach Pro Kit , Bilstine/SLP Shocks , MAC Diff Cover , BFG & OE Wheels C5DD 18x9.5/10.5 , HID 8000K Headlights - Dyno`d @ 319.07 HP & 327.23 Ft-lb ( Tuned by Champ Motors )
09-30-2009, 06:29 PM #2Senior Member
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
yes your right
09-30-2009, 07:13 PM #3
The in/out play you feel in the axles is probably normal. All c-clip style semi floating axles will have some play, its a matter of how much play there is that determines if there is a problem. I haven't seen an axle endplay spec for a GM 7.5" 10 bolt, but for reference, the Dana 60 I was working on today had a spec of .030" endplay. So if you attach a dial indicator and your endplay is way high, .080" for example, you can bet something is probably wrong.
10-01-2009, 02:30 PM #4
DAM 10 Bolts !
Well the car only has to last me till the end of the month then
it`s going into storage , so maybe I`ll save up for that S60 rear over the winter .
in the mean time I`ll try and get her checked out .
Thanks again .
10-03-2009, 12:43 PM #5Senior Member
- Apr 2008
- Madison, WI
The in and out play is normal and your rear end is probablly fine
new axles
By woody84 in forum GTOReplies: 3Last Post: 06-18-2010, 02:59 PM -
Question: Where to buy Axles
By krazyz28 in forum DrivetrainReplies: 2Last Post: 05-28-2010, 05:54 PM -
Axles
By Sarge in forum GTOReplies: 18Last Post: 09-21-2008, 08:08 PM -
axles
By 30th290 in forum CorvetteReplies: 2Last Post: 02-22-2007, 03:32 AM -
axles
By dafizzman1 in forum DrivetrainReplies: 2Last Post: 12-11-2005, 01:37 PM
