Thread: rear end noise!!!
09-30-2009, 02:31 PM #1
rear end noise!!!
rear end gives a du du du du du du du du du du du du du du noice and gets faster with speed. thought it could be flat spots on my tires, but its not. just got new tires. what else could it be?! its getting worse
09-30-2009, 04:49 PM #2
is the frequency of the noise equal to axle rotation or drive shaft, is it the same in turns and going straight. same accelerating, coasting, decelerating?
09-30-2009, 09:29 PM #3
im not quite sure how to tell if its the frequency of the axle or the driveshaft. im pretty sure its the axle. it decellerates when i slow down.. faster when i speed up.... and not quite sure but i think it gets a little louder when i sway to the right like changing lanes at highway speed.
10-01-2009, 08:19 PM #4
come on guys, no help at all?!!!?
10-01-2009, 08:41 PM #5
Why dont you try pin pointing this noise down since you dont seem to have for sure answer to it. Get car, safely, in the air. Remove DS. Start and run car. Theres one. Re-install DS, have a buddy run car slowly with wheels off the ground and listen. Take your rear end cover off and check things out. It might be a U-joint, might be the weak 10 bolt. Thats about all someone over the e-web can do on a vague sound. Just gotta start with the simple stuff, you hear the sound... so you have the best guess.
10-02-2009, 03:34 PM #6
If it changes when you sway from side to side but not netween accelerating and decelerating it could likely be the axle bearing. Get the rear up in the air and run the wheels - see if you can pinpoint which axle it's coming from.
10-03-2009, 04:17 AM #7
Sounds like an old "Platters" tune from the '50's.
SteveC
rear end noise
By rickus in forum DrivetrainReplies: 14Last Post: 07-05-2010, 09:36 AM -
Rear End Noise
By nasdag in forum DrivetrainReplies: 4Last Post: 06-21-2010, 10:22 AM -
Rear end noise
By BDESHIFTER98 in forum DrivetrainReplies: 3Last Post: 10-08-2009, 04:00 AM -
Question: rear end noise
By Brad(WS/Z0.6) in forum DrivetrainReplies: 12Last Post: 02-13-2009, 12:45 PM -
Rear end noise
By 980birds in forum DrivetrainReplies: 1Last Post: 03-22-2007, 03:01 PM
