    Member jcws6's Avatar
    Western Pennsylvania
    2002 Trans Am WS6
    Question Speedometer Problem
    I recently replaced the rear end gears in my Trans Am (went from 4.10 to stock 3.42). Nothing else was changed, and the tires are stock size. I took my car to a shop to get the speedometer calibrated, and they ran into a problem.
    The speed reported in the PCM matched up with the speed on the dyno. But the readout on the speedometer in the dash was off. The shop owner's son, the dyno guy, and I were all confused about why the hell that was happening.
    Thoughts?
    Member Sweet Chops's Avatar
    Manitowoc, WI
    Hugger Orange
    1999 Camaro Z28
    I wonder if you could just pop the needle off and adjust it to where you you need it. Or you can program a taller or shorter tire size into the PCM to get the readout correct.
    Ryan
    2002 Trans Am WS6
    Quote Originally Posted by Sweet Chops View Post
    Can anyone confirm the needle thing?
    The previous owner put some white gauge faces on the instrument cluster, so I asked the tech if maybe the guy screwed it up. He said that he was pretty sure the speedo needle only went on one way & that it was impossible for it to be adjusted like that. He wasn't 100% sure though, so if you guys know, I'm all ears.
    They ended up adjusting the tire size in the PCM so that the speedometer is exactly right at 70, but 3mph off at 35. I didn't ask them to screw with it too much, because I'm planning to put 4.10s in the car next year. But I'd like to figure out what's up with the speedometer, in the meantime.
    Junior Member GONZO SS's Avatar
    NJ
    pewter
    2000 SS
    if they popped the needles when they did the gauges its most likely the problem. that's y a lot of companies r making the overlays were u don't have to pull the needles
    2002 Trans Am WS6
    Question
    Quote Originally Posted by GONZO SS View Post
    Damn. Any recommendations on how to fix it?
    Also, if the needles were off, wouldn't the speedometer be off by the smae amount at all speeds? Right now, it seems like the speedometer is off my a percentage (i.e. the faster I go, the less accurate it is).
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by jcws6 View Post
    I recently replaced the rear end gears in my Trans Am (went from 4.10 to stock 3.42). Nothing else was changed, and the tires are stock size. .................................
    .............................I didn't ask them to screw with it too much, because I'm planning to put 4.10s in the car next year. But I'd like to figure out what's up with the speedometer, in the meantime.
    Why did you go from 4.10 to 3.42 just to go back to 4.10 again next year? I'm a little confused......
    And, I agree with above. The needles were pulled off when doing the white faced gages and weren't put back on in the correct position.
    Manitowoc, WI
    Hugger Orange
    1999 Camaro Z28
    Why didn't you report that you had white face gages in your first post? How else are you going to get the gages on without taking the needles off?
    I'm going to take a guess that the car had 4:10s when you bought it. I bet the guy put the needle wrong to compensate for the 4:10s.
    Ryan
    2002 Trans Am WS6
    I bought the car with 4.10's installed.
    They broke. So I put a used stock rear in it, which was actually cheaper than new gears (go figure).
    Those will probably break, so I plan on getting a 9" someday.
    With 4.10's. That hopefully will not break.
    2002 Trans Am WS6
    Because I reported that I had white gauge faces in my second post.
    The dude at the shop said it was an easy install & very hard to screw up. I doubt the previous owner was smart enough to mess with the needle on purpose, since when the tech looked at my PCM, it was not calibrated for stock gears.
    Ah, well that makes sense now. +1 on the 9". I have the Moser 9" with 4.11 gears.
    Manitowoc, WI
    Hugger Orange
    1999 Camaro Z28
    So is it fixed now, Or you going to just pop the needle off and put it in the correct place.
    Ryan
    2002 Trans Am WS6
    Question
    So is it fixed now
    Nope. The dyno techs could never figure it out. The best thing they could do is screw with the tire size, but the speedometer is still off at low speeds.
    I'm not sure exactly where I need to put the needle. It seems like it's already resting as far down as it can go when the engine's on & the car is sitting still.
    Plus, I'm STILL not sure that the needle would cause the speedometer to be a percentage off (i.e. the speedometer is right at 65mph but ~3-4mph off at 25mph).
  1. Improving Pontiac Speedometer Accuracy - Speedometer Super-T
    Last Post: 02-27-2012, 09:10 PM
  2. no speedometer
    By phil85 in forum Automatic Transmission
    Last Post: 12-22-2010, 04:50 PM
  3. 110 MPH speedometer on Z28
    By Dave-TransAm in forum Camaro / SS
    Last Post: 03-24-2010, 07:39 PM
  4. Speedometer WAY off need some help!
    By ziominix in forum General Help
    Last Post: 05-13-2009, 06:13 AM
  5. speedometer help
    By shortbed454 in forum Stereo and Electronics
    Last Post: 01-13-2006, 10:25 AM
