Results 1 to 17 of 17
09-26-2009, 02:50 PM #1GET SOME
- Apr 2007
- San Antonio, Texas
Pewter Metallic- 2002 Pontiac Trans AM
alternator not getting power HELP ME pLEASE!
My battery has always ran at 12.5 volts so I finally decided to get a new alternator got it all in and took off..went a few miles and all the lights started flashing and it shut off..the little red wire that plugs into it has not fire to it w/ key on or off...where does that wire go to I'm thinkin its crimped or busted or is there a fusable linkage?? Any advice will help!
09-26-2009, 03:44 PM #2
It's an exciter wire. You are going down the right road. If that wire is not hooked up or is broke your alternator will not charge.
09-26-2009, 05:02 PM #3Member
- Sep 2008
- Minnesota
Pewter- 2001 Z28
First of all make sure all your connections are tight, battery, alternator,etc. I know it sounds simple but I have seen it a billion times, then check fuses.
09-26-2009, 05:08 PM #4GET SOME
- Apr 2007
I checked all the plugins and connections and all of the fuses..we checked the wiring diagram at auto zone and it said that single small red wire is for the warning light only..which is why it wasn't reading w/ the test light..
09-26-2009, 05:12 PM #5Member
- Sep 2008
- Minnesota
Pewter- 2001 Z28
will it start
09-26-2009, 05:18 PM #6GET SOME
- Apr 2007
Ya barely when the battery is charged the car is running off battery only..volt meter shows 9 volts then it'll fluctuate up to 12 ish and bounce around then bak down to 9..I've tlalked to a few mechanics and they seem to think its the bettery..the battery tested good but said sometimes there will be a crossover or something that will make the alternator do funky shit..?
09-26-2009, 05:25 PM #7Member
- Sep 2008
- Minnesota
Pewter- 2001 Z28
if it wont start check voltage on the battery. So then recharge it or whatever you have to do to get it to start. Cant autozone test the alternator and see if its good. Im guessing the alternator is bad, I dont know if you bought an ebay one or what, I m not sure if the alternator would actually have power to it when the cars not running. And also are you sure the belts on there good? If the belts on the alternator pulley check tension on the belt.
09-26-2009, 05:29 PM #8Member
- Sep 2008
- Minnesota
Pewter- 2001 Z28
If the car was fine before you changed something in this case the alternator look at that first. Check the voltage reading of the battery when car is off. If its not at least 12v it will probably start like shit. Does the car still run/drive what is the exact problem now.
09-26-2009, 06:35 PM #9
The small red lead to the PCM was working before, no reason it shouldn't work now. If the battery connections are clean and tight then your new alternator is probably bad.
09-27-2009, 07:07 AM #10GET SOME
- Apr 2007
So get this..after about 5 people testing my system and giving me diagnostic advice my dad said maybe one of your battery cells is bad which can throw the alternator off and make it not work right..so I simply took my battery (red cap) out and put a stock battery in and its charging at 14!!!!
09-27-2009, 03:06 PM #11Member
- Sep 2008
- Minnesota
Pewter- 2001 Z28
09-27-2009, 03:11 PM #12GET SOME
- Apr 2007
I did and it was at 12.5 with the car on and off? Then sometimes it would go to nine and bounce back up to 12?
09-27-2009, 03:24 PM #13Member
- Sep 2008
- Minnesota
Pewter- 2001 Z28
put that battery back in just for shits and giggles.
09-27-2009, 03:32 PM #14GET SOME
- Apr 2007
I have it charging on low..I will later
09-27-2009, 03:47 PM #15Member
- Sep 2008
- Minnesota
Pewter- 2001 Z28
I was just joking bro, but maybe keep it as a back up
09-27-2009, 04:00 PM #16
Bad stater...
09-27-2009, 04:29 PM #17GET SOME
- Apr 2007
Nah its an optima they have warrantý plus I can pull strings at some local shops so ill have a brand new one tomorrow
Alternator, power steering pump, LT's
By BlCk02WS6 in forum General HelpReplies: 6Last Post: 02-26-2015, 06:48 AM -
Wanted: LS1 Power Steering and Alternator stuff
By Dozier in forum Parts Wanted / TradeReplies: 1Last Post: 05-13-2012, 04:16 AM -
Wanted: LS1 Power Steering & Alternator Bracket
By jhcrazyboi in forum Parts Wanted / TradeReplies: 0Last Post: 08-15-2010, 10:27 PM -
Power Steering Pump Killed My Alternator
By SMWS6TA in forum External EngineReplies: 13Last Post: 04-26-2010, 02:17 PM -
power loss from alternator?
By DemonSpeed in forum General HelpReplies: 8Last Post: 03-13-2010, 04:47 PM
