Results 1 to 16 of 16
    Junior Member jonnyboy_1985's Avatar
    Sep 2009
    mystic teal
    1998 trans am
    drag radial what to use
    i have been look at some tires for my car has anybody used the toyo proxes TQ thanks jon
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Never used the Toyo's. But you didnt say your goal and purpose of the DR's.
    MT for drag/street
    Nitto for Street/Drag.
    In that order.
    Sep 2009
    mystic teal
    1998 trans am
    well my car is just street drove alot but i like to take it to the track on the weekend sometimes and it just blows the tires off it right now
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    Quote Originally Posted by jonnyboy_1985 View Post
    ok hold up real quick..what do you have done to your car ? ...also are you a m6 or a A4..these questions have to be answered first..if you are not modded and have a A4..i would think you just have shit tires..and DRs would be overkill.....you would want to go with nittos however since you said you just occasionally go to the track..nitto 555r will give you the best street life out of all of them..but they will not hook quite as well as the M/Ts...also worth noting is when the road is cold etc...the tires will be squirly ..they need a good amount of heat into them to stick ..i think that is why they last so long on the street.
    Colorado
    RIP S4 06Tbss
    I rocked Nitto555R for a long time and they worked pretty well as an overall tire. They lasted me about two years, TA was not a dd. Hooked really well when they were heated up.
    Member stephen02ws6's Avatar
    Dalzell, Illinois
    red with black stripes
    2002 Trans Am WS6
    i got nitto 555Rs and they hook pretty good at the track. im cammed, stalled and geared, with tubular LCAs, PHB, and torque arm. they are a pretty good street tire and at the track i do a nice burnout to be able to hook.
    Sep 2009
    mystic teal
    1998 trans am
    it has a nice cam in it long tubes, TB, ported mass air true duel with x pipe out the back 3 in all the way and a full tune my cam size is 228/228 605 lift lsa 112 +2 adv. 6 speed
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by stephen02ws6 View Post
    What are you launching at with them?
    Sep 2009
    mystic teal
    1998 trans am
    i have street tires right now on it so i am pedain it off the line other wise it just roast the tires
    Dalzell, Illinois
    2002 Trans Am WS6
    about 2000 rpm
    Shepherd, Michigan
    98' trans am
    yea i think nitto DRs are right for you.
    about 2000 rpm
    Oh OK. I'm going to the track this weekend for the first time in a while. I'm going to be trying to hook with them at about 4k+. We'll see what happens.
    cammed & slammed Kaotic_ws6's Avatar
    Jacksonville Tx
    2002 ws6 (6 speed)
    well ive never used drag radials but i can launch my car from 3k and it will dead hook most of the time(depending on the road/weather). ive got bridgestone potenzas. 305/30zr19s. best tire ive ever owned.
    1999 mbm Z m6/ forged 346, lt's, wires, ls6 intake, sts rear turbo.
    *SOLD*2002 black ws6- <Bolt ons, ls6 heads, mild cam, dyno tune, full susp. and 4.10s> --440rwhp/395rwtq
    Quote Originally Posted by Kaotic_ws6 View Post
    I'll be running Nitto 555 DRs. I know they are not as good as the M/Ts, but if I heat them up enough, I would think they would hook decent.
    Jacksonville Tx
    2002 ws6 (6 speed)
    yea they should.. i woud have got some drag radials but there so hard to come by for 19s. toyo proxes are about the only ones and there like 800 a peice or somethin like that
    Member qwk93ta's Avatar
    Fairfield, Ohio
    00 WS6
    I use Hooiser QTPs at the track.
  1. Looking for new drag radial
    By RONS98TA in forum Wheels and Tires
    Last Post: 08-16-2013, 05:15 AM
  2. Which is the better Drag Radial?
    By 2001ws6ta in forum Wheels and Tires
    Last Post: 02-03-2009, 09:17 AM
  3. Best drag radial for A4?
    By Z28_06374 in forum Drag Racing
    Last Post: 10-27-2008, 09:52 PM
  4. is 255 Drag Radial enough?
    By ApexVIII in forum Wheels and Tires
    Last Post: 08-24-2007, 01:28 PM
  5. BFG Drag Radial 2
    By gnomee in forum Parts Review
    Last Post: 01-28-2006, 12:36 PM
