Results 1 to 3 of 3
Thread: engine swap
    Sep 2009
    Shreveport,La.
    2004 Silverado
    engine swap
    My truck is a 2004 Silverado with 4.8. Engine which went bad, I bought a 5.3 Gen IV engine. Problem is with the cam sensors. New engine has sensor in timing cover, also rear of intake(lower cover) the plug is different. any help? Thanks
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    Just a question here, Why would you buy a 5.3 when you had a 4.8 and not buy the engine harness and pcm with it?
    Oct 2009
    ontario canada
    2002 z71
    swap parts from old to new motor you said it's a gen iv does it hav dod ? if so you will need harness and pcm to make it work . might be better to buy a similar year motor instead and if your swaping go for the 6.0l lot's more performance options
    If speed kill's do brakes give life ?
  1. Engine swap
    By FOSTER21 in forum Corvette
    Last Post: 09-11-2008, 09:13 PM
  2. engine swap
    By larry111069 in forum General Help
    Last Post: 12-20-2007, 10:37 PM
  3. Engine swap and computer swap
    By mrmiatanut in forum Computer & Tuning
    Last Post: 09-08-2007, 05:10 PM
  4. Engine Swap from v6 / v8...
    By j_j_mccoy RS in forum Camaro / SS
    Last Post: 04-28-2007, 03:23 AM
