Results 1 to 16 of 16
    USMC Y2K_CAMARO's Avatar
    Rocky Point, NC
    Why would this light flash?
    After my cam swap into my 2000 Z28, my SES (service engine soon) light is flashing. It has always been on because of my full exhaust with no cats. But now its flashing. Why is that?
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Blinking is a misfire. Check to make sure your spark plugs boots are all double clicked on. Make sure all the injector wires are good.
    Feb 2008
    NEW JERSEY
    PEWTER
    2001 TRANS AM WS6
    +1 BLINKY is a missfire
    Florida
    1999 TA WS.6
    Also, Get those codes read!!! That is your first step here.
    Rocky Point, NC
    I found out what it is. Like yall said, the blink is for a misfire, but its because of the cam. So its not "really" misfiring, just from the cam. So, no worries for now. Thanks for you input guys
    Florida
    1999 TA WS.6
    I would get that tuned ASAP. Its flashing, thats never a good thing. I went from a stock cam to a 230/236 and had zero misfiring. Did you read the codes yet? Im going to bet its more then your cam. It should not be misfiring.
    Rocky Point, NC
    I guess I'll read the codes when I get off of work today
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    You are in Arizona, talk to NicD to get it tuned.
    Rocky Point, NC
    I am Frost, just need some money first
    Oct 2009
    ontario canada
    2002 z71
    blinking (S.E.S) light is a catalyst damage indicator not a missfire light . a class 3 (sever)missfire will cause this because of unburned fuel going through the cat's. but other things can also cause this (defective ect sensor )
    sorry to jump in like this hope you find the problem
    If speed kill's do brakes give life ?
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Quote Originally Posted by canadaz71 View Post
    blinking (S.E.S) light is a catalyst damage indicator not a missfire light ......
    It may as well be; it's the only condition that causes that behavior.
    Rocky Point, NC
    Problem fixed. Got a tune, no more blinky light. Nic D said that is was blinking because the cam was lobing so hard.
    Member joedude02's Avatar
    Goose Creek, SC
    Victory Red
    2002 T/A WS6 A4
    what cam do you have now?
    Rocky Point, NC
    Torquer V2 on a 112* LSA
    Goose Creek, SC
    Victory Red
    2002 T/A WS6 A4
    you running a4 or m6? how is this cam compared to the stocker?
    Rocky Point, NC
    M6. Its AWESOME compared to stock. 387hp/372tq to the wheels. Drives on the street great. makes great power across the board, sounds bad ass. Its no one of those cams that makes all of its power at like 6000 rpms and thats it. I'm glad I went with this cam
  1. TCS OFF light flash
    By tav8ws6 in forum Manual Transmission
    Last Post: 10-09-2010, 07:53 AM
  2. Droid X 2.2 now with more flash!!!!!
    By LSCyaL8R in forum Almost Anything Goes
    Last Post: 08-23-2010, 08:20 AM
  3. Dual Flash PCM
    By Naaman in forum Computer & Tuning
    Last Post: 05-21-2010, 10:57 PM
  4. Who is using SCT Flash Xcal2
    By AutomagicLS1 in forum Computer & Tuning
    Last Post: 11-09-2006, 04:02 PM
