Thread: Replaced clutch but.....
09-21-2009, 12:41 PM #1
Ok I put in a clutch kit, half the time it shifts fine, other times the Clutch pedal wont come back out all the way, or just wont at all. If i "pump" it works, but Im pretty sure thats not how its supposed to work.
Should i try bleeding it more? i toke it to a shop and they said they would have to drop the transmission and put a new Clutch Slave Cylinder and Clutch Master Cylinder. They just toke a guess didnt even look at my car
(i toke it to them when i was gonna replace the clutch, but went somewhere else, and idk if they r just trying to get money or what)
2000 firebird
3.8 5 speed stage 1 clutch
09-21-2009, 04:33 PM #2Senior Member
- Apr 2008
- Madison, WI
Did it do this before you replace the clutch? If so then you might need a new master and/or slave cylinders. If not then try bleeding the hydraulics more.
09-22-2009, 09:21 AM #3
when i put the new clutch in, it was cause the other clutch was gone, b4 that it never did it
09-23-2009, 07:45 AM #4
09-23-2009, 11:02 AM #5
Cutlass is always right.... needs new master and/or slave cylinders.
Clutch Replaced-->Now Cruise Control Not Working
By 120inna55 in forum General HelpReplies: 5Last Post: 02-23-2012, 11:35 AM -
Help: replaced clutch now have engine vibration
By old power in forum Manual TransmissionReplies: 2Last Post: 03-27-2008, 07:41 PM -
Had Clutch slave cyl, clutch master cyl, and Clutch kit installed now I got problems
By 7camaro7 in forum Manual TransmissionReplies: 21Last Post: 12-13-2007, 07:41 PM -
Clutch Replaced- New Problem- Help please
By qrunchi in forum Manual TransmissionReplies: 2Last Post: 02-15-2007, 07:04 AM -
The SS has been replaced......
By pinky93 in forum Camaro / SSReplies: 40Last Post: 09-15-2006, 12:03 PM
