Thread: Installing TCS ??
02-08-2006, 04:27 PM #1NecctionGuest
Installing TCS ??
Ok so my rearend is making noise and I gotta replace it. Now theres one on ebay which I could use but it has traction control and my car does not. Is it possible to use this rearend on my car or not. I dont care if the traction control works or not. Like is it possible to use it but just like disable that stuff right on the rear end or what.
Thanks
02-08-2006, 04:56 PM #2Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Sure you can "lift" the sensors and they dont do shit then...TC is an electronic thing anyway...the sensors just feed the computer and the PC then regulates throttle and shit...so no worries.....what is wrong with your Diff man? What is happening?
02-08-2006, 05:01 PM #3
I thought the traction control just read wheel speeds from the rear wheel ABS sensors? Your car should have those regardless. I think it should be a straight forward swap. You will need a 98+ rear end, as 97 and older had 3 channel ABS that measured speed at the ring gear. 98 and newer cars have four channel ABS which measures both rear wheel speeds.
Also, if you end up with a different ratio, you need the VCM edited to correct your speedometer.
Edit: I can't spell/type
Hammer - hammertime.us
2001 Light Pewter Metallic Camaro SS, 6 speed
K&N, SLP Lid, SLP y-pipe, GMMG cat-back, Lou's Short Stick - more to come!
02-08-2006, 05:11 PM #4Grand Imperial Wizard
Hammertime...your a good kid...WTF does this mean anyway?
Dont smoke crack kids....knock that shit off....
Originally Posted by HammerTime on drugs
02-08-2006, 05:49 PM #5Wow, what a difference one letter makes. That should have been:
Originally Posted by Sarge
And I think leaving the sensors off or disconnecting them would render the ABS inoperable.I thought the traction control just read wheel speeds from the rear wheel ABS sensors?
But I'm not a mechanic, I'm a crackhead who likes mechanical things!
02-08-2006, 05:58 PM #6Grand Imperial Wizard
Well I'll be...I shoulda know that....no sir ABS senbsors are located in a different place...( I threw a letter in there...I'll let you figure it out
02-08-2006, 06:40 PM #7NecctionGuest
Well my car does have ABS and so does this rear end. I was just wondering about the traction control cuz my car doesnt have it but the car from which this rear end is coming from does.
My rearend is basically howling. It still works seemingly fine but it makes a hell of a lot of noise when the car is in gear, especially on highways. Ears bleed after a while. It sucks
02-08-2006, 09:06 PM #8Howling.... sounds like gears....if the axels and bearings are still good why replace the whole rear? Bearings usually make a nasty grinding/growling sound...if it starts that stop driving it before you pit the axels. I'd be cautious of buying a used rear on e-bay....never know the condition until you tear into it....could end up buying a rear worse then the one you have
Originally Posted by Necction
02-09-2006, 05:59 AM #9NecctionGuest
Problem is , it seems impossible to find one locally here in Ontario Canada. But I am kinda worried about ebay rears though. Unless its scrapped the only reason i can think of for someone to take the rear out is if theres something wrong with it. Id hate to get stuck with another crappy one.
But yeah there doesnt seem to be any grinding noise. When Ive posted a question about whether its possible to repair a rear end, everyone just said to buy a new one. But I dont really have the change for a 12 bolt
02-09-2006, 09:19 PM #10Well, you'll have to ask yourself, are you planning to modify your car? How much power are you planning to put to the ground, and how much tire.
If your car is going to remain mostly stock, then its a hell of a lot cheaper to have your rebuilt and know what you are getting. I'd bargain that many of the people who get 12-bolts do it after they've upped the power and broken the stocker. If you make enough power to keep breaking it, then its money well spent to buy one you won't break. I'm sure you can get it rebuilt for way cheaper than a 12-bolt.
02-09-2006, 09:32 PM #11
The traction control car has sensors at each wheel on the rear axle-Otherwise there is only one sensor in the middle.The question is can you hook up the ABS by switching sensors with your old axle.Anybody know the answers to that? I agree you're better off repairing your old one.
02-09-2006, 09:59 PM #12SUPREME member-oderator
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
another vote for why buy a whole new rear, fix the one you have
Installing a Cam?
By Justin23454 in forum Internal EngineReplies: 14Last Post: 07-01-2010, 10:31 AM -
installing lt1 over the top
By fastlt196 in forum LT1Replies: 6Last Post: 04-17-2009, 07:13 PM -
By fastlt196 in forum LT1Replies: 0Last Post: 03-16-2009, 08:37 PM -
about to do my first mod.... installing an slp lid
By derrinx in forum External EngineReplies: 23Last Post: 08-08-2007, 04:13 PM -
installing a cam
By timd13 in forum General HelpReplies: 2Last Post: 09-10-2006, 04:45 PM
