Results 1 to 20 of 21
Thread: Sound coming from back of intake
09-21-2009, 10:22 AM #1
Ive got this sound that comes from the back of the intake area when i hit the throttle abruptly from idle. for example when i pull up on the throttle cable quickly or step on it while idling or very low rpm. But doesnt do it if i use the throttle normally or gradually, just when i make the equivalent of stomping on it.
It is a whooshing sound or an air sucking sound that seems to come from the back somewhere towards the top of the engine. It really sounds like its pulling in air real fast, but once the rpms catch up it stops. so in other words it is like 1 sec. and it seems like the rpms will drag for a sec and then catch up.
Has anyone had this or heard it before and can offer some insight, its a gm stock replacement LS1 long block that has about 30K on it. I guess the intake was reused from last engine which had 80K on it.?Last edited by bryceslu; 09-21-2009 at 10:28 AM.
94 m6 Formula - Sold
2000 NHRA Formula - Always For Sale
09-21-2009, 11:16 AM #2King 0f n00bz
- Jan 2006
- Shepherd, Michigan
sounds normal to me.
09-21-2009, 12:26 PM #3
09-21-2009, 12:29 PM #4King 0f n00bz
- Jan 2006
i think its the acoustics of the engine ...its just in initial surge of air
09-22-2009, 10:40 AM #5
Car run poorly? Only thing back there is the OPSU.
09-22-2009, 02:23 PM #6
10-01-2009, 06:42 PM #7
NO offense Shady...
But can No One else confirm this noise or at least say theyve heard it before?
10-02-2009, 04:14 AM #8King 0f n00bz
- Jan 2006
well its really hard to know what you hear without audio ..our engines are very very loud
10-02-2009, 07:40 PM #9
10-05-2009, 01:56 PM #10
OK i just took a video of it...can kind of hear it..and it seems to be coming more from the front area of the intake. I will be making a new thread with the video.
THanks.
10-05-2009, 03:45 PM #11
Updated Sound From Intake w/Video
Ive got this sound that comes from the front of the intake area when i hit the throttle abruptly from idle. for example when i pull up on the throttle cable quickly or step on it while idling or very low rpm. But doesnt do it if i use the throttle normally or gradually, just when i make the equivalent of stomping on it.
Here is the video of it: (feel free to turn up your volume) you can hear it best at the 2nd rev and also the last one.
10-05-2009, 04:29 PM #12
I don't hear anything unusual - the throttle body will make that sound because you're causing a sudden rush of air - am I missing something?
10-06-2009, 05:13 AM #13King 0f n00bz
- Jan 2006
quick question..is your intake 100% stock or is it a lid or a cai etc ?
10-06-2009, 05:28 AM #14Senior Member
- Oct 2008
- Coral Springs, Fl
yeah mine does that, quick blip of the gas and it sounds like air is sucked in somewhere
10-06-2009, 06:34 AM #15King 0f n00bz
- Jan 2006
sounds 100% normal..quieter then mine
10-06-2009, 08:45 AM #16
10-06-2009, 08:46 AM #17
10-06-2009, 09:21 AM #18
10-06-2009, 11:04 AM #19
I think (as you can tell by the replies) that it is normal -get out there and drive it and hev some fun!
10-06-2009, 11:15 AM #20
very possible it's just from the pressure change that's coming from vacuum being pulled on the brake booster. Sitting in class so I can't watch the video but very good possibility it's what I just mentioned.
Screeching sound coming from rear of the car - sound clip.
By Tataocb in forum General HelpReplies: 45Last Post: 07-21-2016, 08:12 AM -
Sound Coming From Motor
By animal323 in forum Internal EngineReplies: 8Last Post: 12-05-2009, 05:03 PM -
Help! Sound coming from driveline!
By LS1Formula01 in forum DrivetrainReplies: 0Last Post: 08-09-2007, 06:14 AM -
By LS1Formula01 in forum DrivetrainReplies: 0Last Post: 08-09-2007, 06:12 AM -
thumping sound in the back sounds like it is coming from driver side.
By dafaic in forum LT1Replies: 2Last Post: 11-24-2006, 07:36 PM
