Thread: monsoon amp question
02-08-2006, 12:19 PM #1
- Pittsburgh, PA
does the monsoon amp send the same signal to the sail panels as it does to the front mids? for clarification, is it:
2 Lefts and 2 Rights
~or~
FR/FL
RR/RL
second question, what amp is good to replace the stocker and will work with the stock HU??
02-08-2006, 10:12 PM #2
You would need to get a plug in harness to give you some rca outs or wire in a converter to give some rca outs if you wanted to add a amp. I had a line level to rca converter running off my stock HU for awhile, then added a Kenwood later. Sounded pretty good with the line level converter, but sounds much better with the Kenwoods 5 volt outs. Trying to figure out which wires go where from the Monsoon amp would be more of pain than rewiring the car. You would want new speakers if your adding more power too and the stock wiring is not very big, so I wouldn't do it even if it could be done.
I know the front door woofers work off the F/L and F/R, because when I tested the new infinity's I set the fader to the front and tested the L and R. Now the sailpanel subs I am not positive about, but when I tested my far rear Pioneer 4inch to adjust the freq going to them I noticed the sub didn't move much even on real low bass songs, I also noticed the same thing when I tried only the front speakers, but the subs moved more when the front and rear channel was centered, so it may be that the subs are run together with the front and rear channels and the far rear 4inch are the rear channel only. I may be wrong, but seems logical the subs wouldn't be channel specific, since they don't put out any highs.Last edited by rotwiler; 02-08-2006 at 10:26 PM.
02-09-2006, 05:03 AM #3
ok, i got the 4 wires in the front, but no AMP where the spair tire is, does this make any sense at all?
02-09-2006, 10:23 AM #4
The stock Monsoon amp is near the spare tire, you need to look at the hump area and there should be a black plastic cover over the amp. It is right above the area the stock jack is. It isn't actually right next to the spare tire.
02-09-2006, 10:30 AM #5
i took the cover off, moved the tire looked behind it and didnt see it, i can look again when i get home though i guess.
02-10-2006, 03:13 AM #6
- Jul 2005
- OHIO Go Buckeyes!
Arctic White- '07 Trailblazer LT
The POS Monsoon amp is located forward of the spare tire. It's mounted to a plastic plate above the rear wheel and is located on the fender side of the plate.
02-10-2006, 04:58 AM #7
alright, i found an AMP boys, its not in your location, but it is under a kick panel down from the glove box
02-10-2006, 06:08 AM #8
- Jul 2005
- OHIO Go Buckeyes!
I kinda doubt that is an amp. An amp is too big to hide behind the kick panels. What you found is probably a crossover from a previous installation. Are you the car's original owner?
02-10-2006, 09:01 AM #9
- Pittsburgh, PA
Originally Posted by White Rascal
zboner, you stole my damn thread, bi-atch
02-10-2006, 01:29 PM #10
there is no amp in the rear hatch im telling you i looked all over for the dayum thing, do i need to take pictures to show you?
02-10-2006, 01:50 PM #11
- Jul 2005
- OHIO Go Buckeyes!
yeah, why don't you do that?
02-13-2006, 07:27 AM #12
- Pittsburgh, PA
BONER GET YOU'RE OWN FUCKING THREAD!!!!!
i'm going back to my original question: does the monsoon amp send the same signal to the front mid bass, as it does to the sail panels or do the sails get a lower frequency?
monsoon question
By gfeller2006 in forum Stereo and ElectronicsReplies: 1Last Post: 07-23-2008, 12:40 PM -
question about monsoon in my '00 Z28
By allbaugh_04 in forum Stereo and ElectronicsReplies: 3Last Post: 04-01-2007, 11:13 AM -
Monsoon Question
By msb304 in forum Stereo and ElectronicsReplies: 5Last Post: 11-30-2006, 07:17 PM -
monsoon question
By astyles in forum Stereo and ElectronicsReplies: 4Last Post: 04-13-2006, 03:59 PM -
Monsoon question
By plucas in forum Stereo and ElectronicsReplies: 7Last Post: 01-22-2006, 02:26 PM
