09-14-2009, 09:20 PM #1caraholic
- Jul 2007
- most miserable city in the US
blue green chameleon- 1998 Trans Am
bogging/dieing when switching from Park to Drive
i have a 95 z28, the car seems to wanna die or sometimes it even does die(when hot out 100+) when you switch the gears (A4). the car starts up fine but when i switch it from Park to Drive the rpms drop really low 1-400 rpms then it slowly steadys out. it does it also does it when you switch to reverse. the car has ported heads, cam, slight engine bore, its tuned but not dyno tuned only street tuned. the idle is set at 850 and it rarely idles there. no codes or anything, also car sometimes boggy while driving in low rpms.
09-15-2009, 08:46 AM #2Member
- Feb 2008
- Russellville, MO
TPS might be bad. I had one go bad and it didn't throw a code. The IAC might be bad too. Try cleaning the MAF sensor.
09-15-2009, 09:29 AM #3
09-15-2009, 09:37 AM #4
FYI Becarefull when cleaning the MAF. You can easily ruin it if the wrong chemical is used to clean it. I'd pull the IAC first and check it for carbon build up first then clean if needed.
09-15-2009, 09:40 AM #5
09-15-2009, 04:16 PM #6caraholic
- Jul 2007
ok well i changed the plugs, the #2 cylinder plug was cracked and the #7 plug was covered in goop, maybe from when i seafoamed. the car smoked like crazy when i seafoamed i meen thick nasty smoke. worse than my 02 camaro and 01 ws6 combined. anyways the new plugs have made a world of a difference in the idle but its still doing the bogging thing when switching gears, its not as bad but it still does it. gonna work on the tps now......
09-15-2009, 09:02 PM #7
Keep in mind through all of this that your tune might just be shit, and is contributing to or compounding other problems. But keep checking all of what has already been mentioned, as they are mostly cheap and easy things to check.
09-17-2009, 06:47 PM #8caraholic
- Jul 2007
Last edited by ggino85; 09-17-2009 at 09:08 PM. Reason: started new thread because it was a different issue
Skyline Drive ride, Shenandoah State Park
By 98Hardtop in forum Almost Anything GoesReplies: 17Last Post: 10-30-2012, 04:59 PM -
bogging out
By 98camarols1 in forum General HelpReplies: 29Last Post: 11-06-2011, 04:36 AM -
Virginia Motorsports Park Drag Racing and Car Show - PY Pontiacs In The Park
By Ed Blown Vert in forum GTOReplies: 0Last Post: 11-30-2007, 06:00 PM -
noise from bottom of car when put into drive and reverse but not in park
By tx77015ls1 in forum General HelpReplies: 3Last Post: 10-18-2006, 07:08 AM -
Is there still a Animal drive through park in Grand Praire?
By Street Fighter in forum Texas MembersReplies: 5Last Post: 05-24-2006, 06:55 PM
