Results 1 to 10 of 10
    Member jsmith564`'s Avatar
    Apr 2009
    covington ga
    yellow
    2004 gto
    help with an import
    sorry to post about an import.. and if this needs to go to the tech section i'm sorry to have posted it here..
    i searched google, and different eclipse forums w/o luck. car in question is a 99 eclipes with a 420a 2.0 4 cyl with 5 speed. problem is it's sputtering at low rpms/taking off. this is my girlfriends car and would like to fix the issue.
    i did some maintenance on it today just bacause it needed it, plugs with proper gap, wires, fuel filter, and new batt(old on had a dead cell). i cleaned the sensors around the TB but not the TB itself. i also checked the coil for a good blueish/whiteish spark. no vac. leaks. ohh it once had a O2 code that was cleared with a scaner. but not replaced. there is no CEL on the dash.
    i'm sure i'll end up figureing it out before long. but wanted a lil help from you guys/girls.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    I am trying to remember if that is the version with the MAF integrated in the air filter canister. Is it a turbo? Definately replace the O2 sensor.
    Apr 2009
    covington ga
    yellow
    2004 gto
    non turbo and SD from factory or non maf.
    02 is on the list.
    Apr 2009
    covington ga
    yellow
    2004 gto
    bump..
    any more idea's? new O2 with no change.
    i dont like how this thing sputters like this.. one slip up putting out in traffic could be bad.. i did'nt know how bad it was till i drove it the other day. i really want to get this fixed. i'd rather her drive the goat then this death trap.
    North Jersey
    2004 GTO M6
    Could be a couple of things. Blocked cat, dirty throttle body, fuel pump on the way out. Have you used any fuel system cleaner at all?
    Did you replace the cap and rotor?
    Apr 2009
    covington ga
    yellow
    2004 gto
    TB is still a lil dirty, will try cleaning. she nor i have put in any fuel cleaner. i want to add the 2 cycle. i told her that i use it in the goat. thats all i had to say to convince her it was ok to use.
    i talked with an import friend of mine who had a similar problem with a acura 4cyl 5 speed. he said it was the TPS. i already took the sensors off the TB and cleaned them, but that dont mean either one is'nt on it's way to takeing a shit.. Still no Check Engine Light.
    this car has a coil pack, and has a very good blue/whiteish spark.
    it sputters at low rpm/take off. >1200rpm
    Senior Member 00LS12LS6Z28's Avatar
    Bristow, VA
    2000 Camaro Z28 (sold)
    How many miles are on the car? Could be fuel pump/lines?
    Apr 2009
    covington ga
    yellow
    2004 gto
    Quote Originally Posted by 00LS12LS6Z28 View Post
    sorry.. it has 120,000 as of yesterday. always changed the oil at around 3-5k.
    i'm not sure about the fuel pump. i'll look into it. btw.. the engine runs smooth, no misses, no skips. this is with out running a compresstion test, which i can do by the weekend. untill then, i'll read up on how to check the fuel pump for proper output.
    **somthing to add to the list. the cam sensor has had a small oil leak for a while. i also fixed that with a new OEM gasket and cleaned the mateing surface with cleaner but did'nt clean the sensor itself. it could be jamed with oil/crap in the plug area.. giving weak signals.
    nj
    90 Mustang 5.0
    ok........... spray for vaccum leaks again, AND spray around the fuel injectors, if the o rings go bad, they will leak.
  1. Lsx import!!
    By bluehawk2000 in forum Almost Anything Goes
    Last Post: 02-15-2011, 10:44 AM
  2. Gay Import Quote
    By WS6ICK2K in forum Almost Anything Goes
    Last Post: 03-25-2008, 06:22 AM
  3. a fun import
    By jimmybling31 in forum Kill Stories
    Last Post: 02-25-2008, 06:10 PM
  4. turbo import vs me
    By mrr23 in forum Kill Stories
    Last Post: 10-23-2007, 02:13 PM
  5. my little import
    By jbb6811 in forum Domestics and Foreigns
    Last Post: 06-08-2007, 10:39 AM
