    Sep 2009
    Austin,TX
    Blue
    1999 Z28
    Interior lights quit working: ASR and Lower Fog
    Is there a fuse for these?
    Im talking about the 2 switches in the middle of console
    1 is for the ASR and the other turns on/off the lower fog lights
    When I switch the ASR off, dash still tells me "ASR Off" but it seems the fog lamps are not working at all
    Bragg NC
    Met. Sunset Orange
    01 SS
    There is a fuse in the block and it just so happens to control your fog lamps and your interrior lamps, there is also a relay...
    Chaces are its loose, or bad.
    J
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Or the foglamps are burned out
    Sep 2009
    Austin,TX
    Blue
    1999 Z28
    Thanks for replies
    So if the fog lights burn out they will blow the fuse that controlls the interior switches ?
    I would think the switches would still work and light up even if the outside bulbs so bad ( and both at the same time ? Somehow I doubt it)
    And why would the ASR light go out too
    Sep 2009
    Austin,TX
    Blue
    1999 Z28
    Quote Originally Posted by sunsetorangess View Post
    J
    I will see if I can find it
    Do you know which one it is ?
    The relay would be where ?
    Sep 2009
    Austin,TX
    Blue
    1999 Z28
    I checked the fuse diagram but dont see any that mention fog lamps or ASR etc
    For some reason the Fog Lamp switch now lights up, and one of my bulbs isnt working
    Not sure whats going , but how hard is it to replace bulb?
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Quote Originally Posted by CJoel View Post
    The only thing that blows a circuit breaker or fuse is a short.
    I was just suggesting that the bulbs maybe burned out.
    Sep 2009
    Austin,TX
    Blue
    1999 Z28
    Quote Originally Posted by rbob93 View Post
    Ok thanks
    Is the bulb hard to remove from the lamp ? Im guessing you pull it from under the car? Just twist out like the headlamp bulb ?
    Bragg NC
    Met. Sunset Orange
    01 SS
    The fog lamps come out as an assembly...
    J
    Sep 2009
    Austin,TX
    Blue
    1999 Z28
    FYI
    Changed the one bad bulb and the interior lights are now working as normal
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    ^^ Cool
    Was it as easy as others have stated?
    Never changed one myself.
    Sep 2009
    Austin,TX
    Blue
    1999 Z28
    ^^ Cool
    Sorry for the late response
    It wasnt that hard to change out just 2 10 mm bolts and just be sure to remember exactly what position the bulb is inserted because visibility is poor
    Basically, you cant really see what you are doing unless you got completely under the car, but you can easily reach it with your hand so try to remember the bulb alignment
    It only fits one way
  1. Replies: 2
    Last Post: 02-23-2013, 06:11 PM
  2. My tach quit working
    By socmninja in forum Camaro / SS
    Last Post: 04-07-2007, 07:39 AM
  3. Blinkers quit working??
    By txff636 in forum General Help
    Last Post: 02-22-2006, 07:33 PM
