Results 1 to 20 of 22
    I rather be wakeboarding SexyWS6Mama's Avatar
    Central TX
    Sunset Orange Metallic
    2002 WS6
    Door molding removed
    I finally made the leap and took off those nasty looking door ding moldings...literally I decided yesterday when I was fixing my turn signal that those things need to go. What pushed me? They were starting to discolor and that's just nasty.
    I'm having a tough time removing some of the foam/glue stuff. I tried Bug and Tar remover and that helped. Then I got some Goo Gone...(I haven't tried it yet; but will this morning)
    What do you guys use to get it off? Did you just use your fingernails to remove some?
    War Machine BIG GUNS's Avatar
    St. Louis MO.
    00 Trans Am/Auto
    Yeah, the majority of the glue has to be rolled off with your thumb. You might get a blister but, that is normal for this stuff.
    After its all removed, you can then use some goo gone etc. I used some of that bumper sticker remover in a can and then washed it real well.
    Central TX
    2002 WS6
    yeah my thumbs were numb LOL thanks
    St. Louis MO.
    00 Trans Am/Auto
    Its really about the only way baby.....Unless you get someone to pass out and then use their thumbs.......lol.
    Central TX
    2002 WS6
    LOL
    Member egod's Avatar
    Feb 2008
    Chicago
    1999 Trans Am
    do you have to wax after you remove it?
    St. Louis MO.
    00 Trans Am/Auto
    Yes. Just removing the molding will still show an outline of where the molding was.
    Even with my black car, I could still see the outline until I used a polish and wax. Then, it didn't even look like it had molding on.
    I Drive A 95' AfterYou's Avatar
    Aug 2009
    Granbury, Texas
    01' Firebird Pewter
    98' Trans Am Black
    I just used a razor made of plastic made for removing decals and such but i just pulled/tore and cut it off then for the extran glue i took the razor and went up and down on itwhile applying pressure and it will come of pretty easy
    a good idea for making it a bit easier is to keep it wet
    Member stephen02ws6's Avatar
    Dalzell, Illinois
    red with black stripes
    2002 Trans Am WS6
    once i got the main strip of glue off, i used WD40 to take the rest of the glue off. i then polished where the strip was so you couldnt tell it was there.
    Central TX
    2002 WS6
    passenger molding gone and never to be seen again.
    My fingernails and thumbs hurt, so the drivers side is half done until I get feeling back into my fingers LOL
    What type of plastic razor? Did you make it?
    P.S. I just installed an LED 3rd brake light too. It looks good!
    Member 01 LS1 Formula's Avatar
    aurora colorado
    2001 formula
    do you have any before and after pics
    Central TX
    2002 WS6
    Quote Originally Posted by 01 LS1 Formula View Post
    of molding or brake light? If so, I'm sure I can find some....the molding is half done right now
    aurora colorado
    2001 formula
    both
    St. Louis MO.
    00 Trans Am/Auto
    You should have that shit done by now girl.
    I used a 3M adhesive remover.
    Then polished and waxed.
    Junior Member coloLs1's Avatar
    fort lupton, Colorado
    2001 trans am
    ok, so if you havent got the glue off yet then what you need is called a chizzler (plastic scraper tool, and some mineral spirits (avail at any place that sells paint like wal-mart, home depot) the mineral spirits will NOT harm youre paint or clear, dump some of that stuff on the glue and rub it into it. let it sit a minute and use the plastic scraper tool to get the glue off, we use it all the time at the paint/graphics shop i work for. hope that helps ya out a little bit. if you need a chizzler then let me know, i might have a couple laying around
    lmpounded SandmanWs7's Avatar
    Dallas, Texas
    2007 CTS-V
    Use Ronsonol lighter fluid. I have used it to remove emblems and old stickers. Works great!!
    Junior Member wilsonls1's Avatar
    Arizona
    pewter
    1999 chevy camaro z28
    same here. worked great
    Military Muscle :usa: MYSCZ06's Avatar
    Columbia,SC
    Millienum Yellow
    2003 Corvette Z06
    when I took mine off in aug 2003 in SC it was so hot that I was able to pull off the moldings and 90% of the crap stuck to the molding the rest I basically rolled up into a ball and pulled off. I then used some goo gone to clean up the residue then waxed it!!
    Central TX
    2002 WS6
    I went to the lake to wakeboard so the other one is not done....will be working on it today! Will post pics soon!
    wakeboarding took top priority. LOL
  1. Removed My Side Molding!
    By My00Z28 in forum Appearance Section
    Last Post: 08-05-2011, 07:40 PM
  2. Removed my side molding too!
    By fluke in forum Appearance Section
    Last Post: 07-13-2008, 01:37 PM
  3. Side Molding removed
    By Formula Dave in forum Appearance Section
    Last Post: 03-30-2008, 06:08 PM
  4. Side molding removed on T/A's?
    By Firebird Phoenix in forum Appearance Section
    Last Post: 03-18-2008, 08:22 AM
  5. Door molding???
    By bwinch in forum Appearance Section
    Last Post: 02-21-2007, 10:21 AM
