    Junior Member blackula 99's Avatar
    melbourne fl
    99 frc corvette
    stock rockers w/ aftermarket valvetrain...help!
    Recently assembled my 273 xer cam w/ ls6 cnc heads milled just .003. Have stock new timing chain,stock lifters and pushrods, stock rockers but with the heads there are aftermarket springs. Which valve adjustment should I go by,the standard gm adjustment with just torqueing them to 22 ft lbs or as I have seen listed, 0 lash,tighten to half a turn? Reccomendations for this application? Have ordered a pushrod length tool also...Thanx again
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    I see stock casting heads, clean up mill, and stock rocker arms. I dont know why you would want to do anything different then torqing them down to 22 ft lbs... cranking the motor over a few times and checking.
    Stock 22 ft/pounds. That goes for anytime you run the stock rockers.
    Arizona
    That is correct. The stock rockers are not adjustable. The lifter preload and valvetrain geometry is set by the pushrod length.
    If there is an issue with lifter preload or geometry you would need one of two things, either a different length pushrod or spend the extra dough on an adjustable valve train setup.
  1. stock rockers...ls1..ls3
    By Super6 in forum Parts Wanted / Trade
    Last Post: 02-01-2016, 05:14 PM
  2. 590 cam with stock rockers?
    By King06C6 in forum Corvette
    Last Post: 12-15-2008, 08:25 PM
  3. WTB: stock rockers, stock pushrods and other parts
    By jimmy 2 times in forum Parts Wanted / Trade
    Last Post: 10-31-2006, 12:20 PM
  4. 98-02 Aftermarket Parts Also Brand New Jesel Rockers
    By CChatter9 in forum Parts For Sale / Trade
    Last Post: 10-03-2006, 09:50 PM
  5. Ton of 98-02 Aftermarket/Stock Parts Plus New Jesel Rockers
    Last Post: 10-03-2006, 09:34 PM
