Thread: Throwing Too Lean code P0171
09-05-2009, 05:55 AM #1
What should I check on this? 2000 T/A WS6. Just added BBK SSI Intake, 85 mm throttle body, SLP CAI, smooth bellows, lid, K&N air filter cleaned, Magna Flow cat back. While driving it popped the code. Also noticed that when warmed up and driving the rpms would not drop for a few seconds when I engaged the clutch or let off. If I let the tranny slow it down it would eventually hit a position that dragged the rpms to normal.
09-08-2009, 08:36 AM #2MOTOR CITY MARO'
- Nov 2005
- LIVONIA,MICHIGAN
PEWTER- 2000 CAMARO SS #3821
Is the MAF stock? If not put the stock one back in, or try cleaning the OEM one with MAF cleaner from any auto parts store. DO not touch or wipe the wire inside the MAF.
09-08-2009, 04:07 PM #3
09-08-2009, 04:18 PM #4
That SLP MAF has made your PCM think the car is running lean and is probably dumping a lot of extra fuel trying to compensate but never satisfies the condition.
You can also check to make sure that you did not scorch/melt your O2 sensor wires with the new intake/exhaust.
09-09-2009, 06:36 AM #5
09-09-2009, 06:42 AM #6Member
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
Clear codes with a scanner the same thing happened when I put my slp maf in it ran great at first then after a couple hundred miles it through the same bs codes I put the stocker back in and had the codes cleared have not had the problem since.
09-09-2009, 06:48 AM #7
If you had your stock one stored for a while when you were running the SLP MAF, I would guess it is dirty.
Even if it looks clean, I would still buy some MAF cleaner and spray the hell out of it. The P0171 code is usually the MAF. It looks like SSTOD said the same thing.
I am not sure on this, but it may take a while for the PCM to relearn
with the new MAF.
You could also check for a vacuum leak downstream of the MAF. This would trigger the same code.
Help: Lean Air bank 1 and 2 codes (P0171, P0151)
By MeanGreen98 in forum General HelpReplies: 36Last Post: 01-24-2012, 05:17 AM -
Throwing codes for bank 1 and 2 being lean.
By !!!FAST!!! in forum External EngineReplies: 2Last Post: 08-14-2010, 07:06 AM -
P0171 Code on 2000 SS
By chevy8758 in forum Computer & TuningReplies: 2Last Post: 08-14-2009, 02:31 PM -
2000 Camaro SS getting code P0171
By chevy8758 in forum General HelpReplies: 4Last Post: 08-14-2009, 05:55 AM -
Does anyone know why I keep getting this code? P0171
By BlkNBlkC5 in forum CorvetteReplies: 6Last Post: 12-26-2006, 07:57 AM
