    Aug 2009
    Lexington, Ky
    2001 WS6 Trans Am
    Are the front parking lights dual element bulbs?
    I just picked a WS6 recently and am working out the little problems.
    With the headlight switch in the OFF position, then the fog light switch is turned on, only the driver FRONT parking light is lit...If I turn the headlamp switch to the parking lamp ON position, both front parking and side parking lights are lit, then I turn the fog lamp switch ON and both fog lights come on and the driver parking lamp is now BRIGHTER than the passenger parking lamp.. SO, i was wandering if the parking lamps have dual elements in them??? (like the stop/brake lamps)...Thanks....
    Feb 2006
    2002 WS6
    yes they have dual elements, and it not uncommon for them to collect water in the socket and short out the lamps.
    The fog lights only come on in the park position or the head light position on low beam.
    I use 3157NA lamp, I think there are two options, the other is 3150NA I think.
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    They work as kinda like daytime running lights when your headlights/parking lights are off, when you use your blinker, they'll get dimmer then go back to brighter, and so on. When you turn your parking lights on or the headlights, they work the oppostie.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    get ready to buy a lot of turn signal bulbs,common problem on 98-02 t/a. advice:when going through a carwash make sure the car is turned off,if running the water will,in most cases,cause your turn signals bulbs to pop.
    Jul 2009
    Custom Swirly Black
    2001 WS6 M6
    Quote Originally Posted by 02transamce View Post
    I've heard LEDs are the solution to that problem.
    Aug 2009
    Lexington, Ky
    2001 WS6 Trans Am
    thanks picked up some 3157's, figured one of the elements was burnt, just wanted to make sure.... Thanks fellow LS1 members....
  1. Parking lights don't come on?
    By jayroca in forum Firebird / WS6
    Last Post: 05-19-2016, 05:54 AM
  2. Help: Driving lights & parking lights on with headlights down ?
    By AZBlackBird in forum Firebird / WS6
    Last Post: 04-02-2012, 08:48 PM
  3. Question: Do your parking light bulbs get like this ?
    By Blue2KTA in forum General Help
    Last Post: 02-22-2011, 06:56 AM
  4. Parking Lights
    By Airguy in forum Firebird / WS6
    Last Post: 10-15-2007, 04:10 PM
  5. Tail lights wont work...not the bulbs
    By BlueBird in forum Stereo and Electronics
    Last Post: 10-15-2005, 09:38 PM
