    Sep 2009
    Montgomery
    2010 Camaro LS
    396 ci LS/Vortec?
    I'm going to sum this up as best possible
    -I have a near perfect rolling chassic 69 camaro
    -It originaly had a 396 big block in it
    -I would like to build a 396ci LS/Vortec motor
    -I would like to do a 4.1" bore 3.75" stroke (not original spec but close enough)
    -I would like to use a common production engine ex.. 6.0l vortec
    -I don't want to use LS7.. or any aftermarket motor (LSX, LS Race, Warhawk)
    -From what i understand the 6.0l Vortec can only be bored to 4.060 without sonic honeing
    so my question is can i bore the LS3 or L92 to 4.1" safely.. if not can i have it resleeved and bore to 4.1?
    just before anyone ask.. I have a really good connection with a junkyard in birmingham al.. i pulled a 6.0l vortec a few months back with a friend for his 99 camaro (he's in the process of doing a twin turbo install.. he also recommended that i come to this site) anyways the owner only charged me $100 for the motor and differential.. so thats why i would like to keep it in this range of production motors.. economy sucks any penny i can save you know?
    edit: also i'm in no rush at all to complete this project.. while the vehicle is in perfect condition i'm planning on doing the electrical first followed by interior, then paint.. and to finish it i'll do the driveline.. i know for a fact i'm going to use a LS/Vortec motor.. it's just can i make my dream a reality?
    Senior Member 00z28bubba's Avatar
    las vegas, nv
    2000 Z28
    Quote Originally Posted by Three46Ci View Post
    a common setup with the 6.0 that alot of people use on this site is the 402-408 stroker. its common and very easy to do because so many have done it before and will continue to do it. but i think you might get some more specific info if you can tell us which 6.0 it is. there was an earlier model which was the lq4 and the later model dubbed the lq9. both low compression(great for boost even though neither were forged). i know the lq9 was more performance based and had the same cam as a stock ls1. puts out about 375hp 400tq(not 100% sure on that). i think the lq4 has the same ratings as the ls1. i know the casting design was generally the same between the ls1, lq4, and lq9. they just have little things that make differences on them like the heads and intake manifold. the only real difference between the lsx and vortech lineups are the fact that the lsx family from the factory is aluminum and the cortech family is iron. same general design though.
    Sep 2009
    Montgomery
    2010 Camaro LS
    Quote Originally Posted by 00z28bubba View Post
    I understand that and thank you.. but both the lq4/9 can only safely be bored to 4.060" and my ideal for perfect would be a 4.1" bore and a 3.75" stroke opposed to a 4.0" bore 4.0" stroke that the 402ci uses thats why i'm trying to find the max bore for the L92/LS3 motor to see if i can hit the 4.1" bore
    Sep 2009
    Montgomery
    2010 Camaro LS
    new update.. well since i can't bore the 6.0l motor to 4.1" i guess i'll do a .020 overbore and use a eagle 3.9" stroke crankshaft to reach my 396ci build.. kind of a dissapointment since i can't get the stroke and bore similar to the old 396 motor but oh well.. anyways my question now is how have y'alls experience with eagle been on LS motors?
  1. S10 4.8 Vortec 5.7 LS
    By stempy in forum LSx Retrofit and Swap
    Last Post: 07-14-2014, 09:59 PM
  2. Vortec heads on non Vortec block
    By bradyhill1 in forum Internal Engine
    Last Post: 03-23-2013, 01:49 PM
  3. Help: 5.3 Vortec to a 5.7 LS1?
    By philyfz450 in forum General Help
    Last Post: 02-21-2011, 07:09 PM
  4. Vortec 350..
    By SeVeReDiStOrTiOn in forum Almost Anything Goes
    Last Post: 03-23-2009, 05:12 PM
  5. 5.3L Vortec
    By [email protected] in forum Internal Engine
    Last Post: 03-11-2009, 10:04 AM
