Results 1 to 14 of 14
08-19-2005, 07:28 PM #198UltraZGuest
Tons Of Parts For Sale!!!! Some Are On Ebay For Extremely Cheap!!!!!!!!!!!
1.)TSP Clear lid and accell blue colored air-filter (airfilter is brand new, and the lid looks like new also) $100 shipped FIRM
2.)00' LS1 computer $140
3.)BMR Front swaybar (red) with poly endlinks $125
4.)LS1 gauge cluster out of a 00' (have no clue on mileage) $65
5.)sold
6.)LS1 aluminum driveshaft $175
7.) Neck Collar, blue in color, RCI brand. $25 shipped
8.) K&N cold air induction kit for 93-97 cars, it has been painted and then repainted black. Has ALL hardware, extra filter oil, and smooth bellows.. $115
9.) Holley fuel pump $40
10.) Mallory Fuel pressure regulator $80
11.) http://cgi.ebay.com/ebaymotors/ws/eB...tem=7994198251
Lunati Stock Stroke billet crank (3.622)
Manley forged 6.100 rods w/arp bolts.
Wiesco 3.905 forged flat top w/valve reliefs.
rotating assembly
Pictures: http://photobucket.com/albums/v489/9...eco%20Pistons/
EDIT: (It has been welded before, but was ran and the motor made some mid 9 second passes with no problems. There was a block issue and that is why the motor was taken apart. The machine shop checked it over and said it was fine. The rotating assembly was already balanced by LME, so no need to have the assembly balanced.. There are some weld cracks, but they are not in critical spots. The crank won't fail because of them either. The crank was turned 20 under on the mains and will need chamfered bearings. The rods were turned 10 under. Also discovered the crank trigger wheel was never pressed on tight so it was loose when the motor was taken apart. The whole package will be a nice addition in building a forged 347.)
12.)
LS1 STG 2 Ported by Craig @ GTP in Houston, The car was running 9.6's on the 347 and spray – Crain dual springs, ti retainers, 61.5 cc. They are milled 30 thousandths. $1500
LS1 Mac headers, V6 Borla, and Lunati crank, manley rods, wiseco pistons, all on ebay...
headers and offroad y-pipe
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7994194846
Lunati Crank, Manley Rods, Wiseco pistons
V6 Borla Exhaust
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7994192516Last edited by 98UltraZ; 08-20-2005 at 07:26 AM.
08-20-2005, 06:09 AM #2Texas el es Juan Member
- Buda Tx South of Austin
- iTrader
- 0
Artic White- 2000 SS Camaro M6
Bump for the great prices! man someone grab the clear TSP lid!thats what i have and only made so many!!!!
08-20-2005, 01:49 PM #3FBody Priest
- Jul 2005
- Naples, FL
- iTrader
- 0
Artic White- 1998 Trans AM WS6
ill take dibs on the lid. you take paypal? got pics? [email protected]
08-21-2005, 05:24 AM #498UltraZGuest
sent you an e-mail!
08-21-2005, 05:54 PM #598UltraZGuest
1.)TSP Clear lid and accell blue colored air-filter (airfilter is brand new, and the lid looks like new also) $100 shipped FIRM(sale pending)
http://photobucket.com/albums/v489/9...S1%20computer/
http://photobucket.com/albums/v489/9...ont%20swaybar/
http://photobucket.com/albums/b15/GS...uge%20cluster/
5.)LS1 aluminum driveshaft $175
http://photobucket.com/albums/v489/9...%20driveshaft/
6.) Neck Collar, blue in color, RCI brand. $25 shipped
http://photobucket.com/albums/b15/GS...Neck%20collar/
7.) K&N cold air induction kit for 93-97 cars, it has been painted and then repainted black. Has ALL hardware, extra filter oil, and smooth bellows.. $115
http://photobucket.com/albums/v489/9...r%20induction/
8.) Holley fuel pump $40
http://photobucket.com/albums/v489/9...20fuel%20pump/
9.) Mallory Fuel pressure regulator $80
http://photobucket.com/albums/v489/9...e%20regulator/
10.) http://cgi.ebay.com/ebaymotors/ws/eB...tem=7994198251
rotating assembly
11.)
http://photobucket.com/albums/b15/GS..._/GTP%20Heads/
12.) 4- 98 Camaro 5 star painted wheels. Tires are dry rotted from sitting, some curb rash, Might have all the centercaps... $115 shipped a pair or $200 shipped for all four.
http://photobucket.com/albums/b15/GS...maro%20Wheels/
13.)A set of the "wagon wheels" off of a 98' Corvette. They are painted. The rears are nitto NT555 ZR 275-40-18 and the fronts are michelin 17's, pretty sure they are 245 wide... The front passenger rim has a "slight" bent edge.. It drives good and holds air.. it is barely noticeable... I think the front driver's side tire might have an issue because the car was pulling a LITTLE, and the alignment was fine... The front tires have probably 50% tread or so, but they will probably need replaced soon. The rears are in good shape.. they are cracked a little from sitting but not bad... $400 for all 4 wheels and tires... WILL NOT SPLIT TIRES FROM RIMS...
http://photobucket.com/albums/b15/GS..._/C5%20Wheels/
V6 Borla Exhaust
08-23-2005, 10:29 AM #698UltraZGuest
1.)00' LS1 computer ON EBAY
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7995426069
2.)BMR Front swaybar (red) with poly endlinks ON EBAY
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7995428560
3.)LS1 aluminum driveshaft ON EBAY
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7995423877
4.) Neck Collar, blue in color, RCI brand. ON EBAY
http://cgi.ebay.com/ebaymotors/ws/eB...tem=4570761186
5.) K&N cold air induction kit for 93-97 cars, it has been painted and then repainted black. Has ALL hardware, extra filter oil, and smooth bellows.. $115
6.) Holley fuel pump ON EBAY
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7995430725
7.) Mallory Fuel pressure regulator ON EBAY
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7995433389
8.) http://cgi.ebay.com/ebaymotors/ws/eB...tem=7994198251
rotating assembly
9.)
10.) 4- 98 Camaro 5 star painted wheels. ON EBAY
Tires are dry rotted from sitting, some curb rash, have all the centercaps but some are cracked and some black plastic lugnut covers are missing...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7995435427
11.)A set of the "wagon wheels" off of a 98' Corvette. ON EBAY
They are painted. The rears are nitto NT555 ZR 275-40-18 and the fronts are michelin 17's, pretty sure they are 245 wide... The front passenger rim has a "slight" bent edge.. It drives good and holds air.. it is barely noticeable... I think the front driver's side tire might have an issue because the car was pulling a LITTLE, and the alignment was fine... The front tires have probably 50% tread or so, but they will probably need replaced soon. The rears are in good shape.. they are cracked a little from sitting but not bad... All 4 wheels and tires... WILL NOT SPLIT TIRES FROM RIMS...
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7995437166
Package close to $4k new $500 no reserve
V6 Borla Exhaust $60 with no reserve
08-24-2005, 11:57 AM #798UltraZGuest
K&N is sold.
08-24-2005, 09:20 PM #8Junior Member
- Albuquerque
- iTrader
- 0
Blue- 1999 Z28
Headers?
Are the Headers still for sale? How much would you take for them?
Jeremy
08-24-2005, 09:27 PM #998UltraZGuest
sorry they are sold.... for some reason it is not allowing me to edit the original ad....
08-26-2005, 11:42 AM #1098UltraZGuest
5.) Holley fuel pump ON EBAY
6.) Mallory Fuel pressure regulator ON EBAY
7.)
8.) 4- 98 Camaro 5 star painted wheels. ON EBAY
9.)A set of the "wagon wheels" off of a 98' Corvette. ON EBAY
I also have the following...
FRESH 408 motor FOR SALE!!!!!!!!!!!!
This motor is COMPLETELY FRESH!! It was professionally assembled. The heads have roughly 300 miles since the valvejob. The rotating assembly was balanced, and it has brand new bearings and rings being installed.
408 ironblock 10.5:1 compression (with the heads that are on it)
Stage 2 p&p heads 2.02/1.57 valves 4.8/5.3 heads (they are the same..) 65.8 cc (will provide flow sheet from SF600 test)
Comp "R" lifters.
Comp 7.4 hardened pushrods
Lunati 244/252 .624/.629 112 lobe separation
Clevite main and rod bearings
4” crank Eagle
Crower Rods
JE reverse dome 16cc pistons
It will have ALL of the pans and covers. No sensors, crank pulley, or intake though. No dyno time or 1/4 mile passes. This motor is fresh, and has not been run since the new bearings, rings, etc..
$5500
08-30-2005, 05:06 AM #1198UltraZGuest
auctions end around noon CST today!!!!
10-31-2006, 07:49 PM #12your parts guy!!!
- cleveland ohio
- iTrader
- 48 (100%)
trans am 00 ws6- 1998 camaro ss vert
anything left? i couldn't get to any of them, looking for the collar. thanks.
11-01-2006, 02:54 PM #13member
- Clifton Hts.,Pa.
- iTrader
- 0
Black- 2001 Camaro SS
is the rotating assembly still available.let me know.email to [email protected]-thanks
11-01-2006, 07:21 PM #1498UltraZGuest
Tons Of Parts For Sale! New And Used!
By jdubbs928 in forum Parts For Sale / TradeReplies: 9Last Post: 05-20-2010, 06:41 PM -
Tons of F-BODY parts 4-sale, cheap!
By stepuptata in forum Parts For Sale / TradeReplies: 60Last Post: 06-15-2008, 08:28 PM -
Tons of 98 z28 parts for trade or cheap sell
By Frankthetank in forum Parts For Sale / TradeReplies: 44Last Post: 02-04-2007, 07:16 PM -
By Frankthetank in forum Parts Wanted / TradeReplies: 0Last Post: 09-21-2006, 01:01 PM -
Tons Of Parts Starting At A Dollar On Ebay
By 98UltraZ in forum Parts For Sale / TradeReplies: 8Last Post: 10-14-2005, 08:20 AM
Edit Post
