Results 1 to 14 of 14
Thread: Too floppy
    Too floppy
    Minor issue -- installed a SLP lid a few months back and have retained the secondary air system for the time being. The inlet hose from the lid to the air pump flops back towards the engine and pretty much looks like ass hanging there. I tried a zip tie to secure the hose to the wire harness on the drivers side of the radiator, but it still flops back. Anyone ever come up with a solution, or I am just being too picky about things?
    Pony_eater Pony_Eater's Avatar
    Aug 2008
    Murrieta, Ca
    2000 trans am ws6
    I dont understand...secondary air?
    I'm guessing you have a 98-99 lid. This is how I did mine. I used a zip tie too. Nice and secure.
    It's an '02 and it is the hose the feeds filtered air to the secondary air pump. The SLP kit includes a grommet and a short hose with a connector to attach the factory hose to their lid, circled in the picture below:
    Yeah, I've got that now. I have a 2000 SS, but the lid is a 99. I ended up getting the 00-02 hose like you have though from someone here.
    I don't have an issue with it though. You may need a new hose. It looks a bit frazzled at the connector on the lid in the pic. Maybe if it was a tighter fit that would take care of it
    The hose is actually in good condition -- you may be seeing the clamp in the picture (it's not very clear). The problem is that the hose run is simply too long. It does not look bad in the picture from this angle, but from the front it looks way out of place. I am sort of a neat freak...
    May 2008
    Line Lexington, PA
    2002 z28 camaro
    Jeff,
    I think you are being too picky. I had the same problem with mine. Cut the hose down to make it shorter. Cleans it up a little. But just remove the air system and get the codes turned off I ended up doing that and it was great!
    Quote Originally Posted by 02Sweet View Post
    Jeff,
    Yeah -- being OCD is sometimes a pain. I did not think to trim down the hose. That may tighten up the run a bit.
    I am pretty sure I can get away with deleting the air system when I do long tubes. Hopefully over the winter -- just debating as I do not want to have any problem down the road with inspections.
    May 2008
    Line Lexington, PA
    2002 z28 camaro
    If you put headers on WITH CATS you will be fine for inspection with removing the air system. BUT you must get the codes removed.
    I don't have cats on my car but I have a "special" garage.
    Member DaddySS's Avatar
    Bergen Co. NJ
    2000 Camaro SS Conv.
    Why not cut a hole in the lid, get a rubber grommet, and install the hose where it is meant to go with the bracket that holds it?
    http://www.slponline.com/view_product.asp?P=11003
    http://www.slponline.com/view_product.asp?P=21045
    Quote Originally Posted by DaddySS View Post
    Did not know they made a bracket. Thank you.
    Huh... I don't have one of those brackets.
    Bergen Co. NJ
    Yes, with the hose and bracket it makes a nice tidy set up for us anal retentives!!!
    That's me! Can you post up a pic showing the bracket installed?
  1. Floppy gas pedial
    By JBZ28 in forum General Help
    Last Post: 10-30-2010, 05:55 AM
  2. Floppy Shifter
    By SHines-IT in forum Almost Anything Goes
    Last Post: 08-01-2010, 09:37 PM
  3. Is your rear bumper floppy?
    By third_shift|studios in forum Firebird / WS6
    Last Post: 10-02-2006, 05:16 AM
  4. I need help installing a 3.5 floppy drive in PC
    By Mike Hawk in forum Almost Anything Goes
    Last Post: 03-12-2006, 09:06 AM
