    Do I need anything else for a headers install?
    Hey guys,
    I'm about to order some Pacesetter Ceramic Coated Long Tube Headers (No EGR) & Pacesetter ORY-Pipe. And I have some questions:
    If I am getting rid of the EGR & Air pump, what other "parts" will I need to order?
    I am also planning on ordering:
    GM MLS Gaskets (are these good or need something better?)
    Plug-n-play O2 extensions (Are these need if I am deleting the rear O2's?)
    When installed I plan on getting a tune from Frost if I have enough $$$ left over.
    I plan on using this thread from the sticky's above as a guide because this is my first header install on a 98' Trans Am:
    http://www.ls1.com/forums/showthread.php?t=117548
    Bump, also need to ask:
    Can I reuse my O2 sensors or do I have to get new ones?
    Bump
    Anybody?
    I am wanting to order today before wife get's ahold of my funds.....begging!!!
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    You need bock of plate for the egr (I see them on ebay all the time) I would use the o2's you have in there untill after the tune and then replace the front's. I don't know about the gaskets.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    By the way you will want the tune very soon after because the car will run rich at idel and lean under load.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Hey guys,
    The O2 extensions are needed for the front o2s unless you are replacing them with a long-leaded O2 such as the Bosch 13111's. Definitely use the metal gaskets between the headers and heads.
    Let me know when you get ready to get that PCM out, or just if you have any questions.
    Thanks.
  1. 1 hour install headers for LS2 GTO.
    By TmaxicanA in forum GTO
    Last Post: 03-25-2010, 03:05 AM
  2. Need Help, Headers Install
    By karpetcm in forum External Engine
    Last Post: 06-07-2009, 02:47 PM
  3. Headers Going In...Install Q's
    By TheGimp711 in forum External Engine
    Last Post: 02-17-2008, 06:30 AM
  4. What Headers to install ?
    By LTChappa in forum Corvette
    Last Post: 10-23-2007, 04:59 AM
  5. How to install Headers?
    By thelastz28 in forum External Engine
    Last Post: 11-21-2005, 08:42 PM
