Results 1 to 13 of 13
Thread: Drivetrain shakes
08-31-2009, 05:27 PM #1
- May 2008
- Dallas
Black- 99 trans am
Drivetrain shakes
I havnt had this problam very long but my drivetrain has been shaking realy bad whenever i take off from a stop or revers...once im moveing faster then 5 mph it drives smooth, its really hard to get someone close under the car to look at it since the car has been lowerd..and to tell ya the truth this all started whenever i raced a mustang and my car started to wheelhop very bad..what could be the problam?
08-31-2009, 05:39 PM #2
M6 or auto?
08-31-2009, 05:44 PM #3
- May 2009
- Plainwell, Mi
Flame Red / Orange Custom- 1998 Trans Am
98 Trans Am Custom Paint, Ghost Skuls On Racing Stripe + Custom Front Lip, :MODs Tubular K-member, Tubular Upper and lower A-arms, Tubular Control Arms, 4:10's, Cam L-.567/.575 D@.05-.212/.218,1.85 Roller Rockers, P&P Heads, ARH Headers & HF Cats & Y-Pipe, SLP loudmouth catback, +'s
08-31-2009, 07:36 PM #4
- Jul 2008
- Twin Falls, Idaho
blue- 99 Z28 Camaro LS1
I had an '84 Z28 that once the trans mount broke it did the same as yours is doing. Look for that first it's an easy fix.
09-01-2009, 06:25 AM #5
- May 2008
- Dallas
Black- 99 trans am
M6. whenever i shift it dosent clunk it drives fine ..its when i just take of from a stop the car begins to shake..I'm not sure if it matters but it does it worse in revers.
09-01-2009, 06:34 AM #6
09-01-2009, 07:29 AM #7
- May 2008
- Dallas
Black- 99 trans am
I have not had the rear recentered..
09-01-2009, 08:34 AM #8
Should also get an adjustable panhard bar along with your lower control arm relocation brackets.
09-01-2009, 09:20 AM #9
- May 2008
- Dallas
Black- 99 trans am
thats a good idea..I should also invest in some new shocks cuz im still rolling in the same stock ones...is it possible that the shaking could also be coming from the rearend or should i focus on the transmission mount?
09-01-2009, 10:07 AM #10
09-01-2009, 10:17 AM #11
- May 2008
- Dallas
Black- 99 trans am
thats true a have sevral "bangs" under my car mostly under the crossmember..
09-01-2009, 12:12 PM #12
09-01-2009, 12:52 PM #13
I had what seems like the same problem awhile ago. All 4 of my transmission crossmember bolts had backed out maybe a 1/4 of an inch. Blue loctite and a few minutes later it was fine. While you check your mount, check those. Actually get a wrench/socket on them though.
Automotive Harlem Shakes
By trev0006 in forum Almost Anything GoesReplies: 23Last Post: 02-21-2013, 11:57 AM -
Question: car shakes at around 70mph and up.
By dav-02ws6-m6 in forum Suspension and HandlingReplies: 13Last Post: 08-04-2012, 04:20 PM -
Help: 1rst gear shakes the whole car
By sg72201 in forum Camaro / SSReplies: 7Last Post: 08-04-2008, 06:07 PM -
Heads/cam Motor really shakes
By andy670ho in forum Internal EngineReplies: 4Last Post: 03-31-2007, 03:31 PM -
Wheel shakes when braking
By txcosmos in forum GTOReplies: 18Last Post: 02-10-2006, 04:42 PM
