Thread: Sanding
    Member izzhemp's Avatar
    Osawatomie KS
    white/Black
    1999 Pontiac Firebird
    Sanding
    im wanting too sand my hood hatch an top of my car, but ive never done this before so i could use some advice step by step instructions and tips for the best turn out, i dont know what i need so a list of supplies and anything else needed for this process would be great and im trying to keep it cost efficent. thanks
    War Machine BIG GUNS's Avatar
    St. Louis MO.
    00 Trans Am/Auto
    I'd start here and then google for more if needed:
    http://www.iautobodyparts.com/guide_...w_to_sand.html
    Osawatomie KS
    white/Black
    thanks that helped alot
    St. Louis MO.
    00 Trans Am/Auto
    No problem. Better to remind to google instead of getting 8 million different opinions on something that touchy and labor intensive.
    St. Louis MO.
    00 Trans Am/Auto
    oh, one other thing. The article doesn't specify what fine grade is. 2000 to 4000 is fine grade. I think you might find a finer grade than that but, try that and see how that works.
    I used 2000 on the inside intakes of my hood and that prepared it just fine for paint.
    Remember to use an acetone cleaner to remove any impurities after sanding and just before paint.
    Good luck.
    Member Double0me's Avatar
    FT Carson
    Blue
    1999 Blown Trans Am
    Grease and Wax Remover!!!!! and if you get some pices of the blue 4X8 board insulation you can make your own sanding pads. if your working with curves. smnding blocks work well for the flat spots.
  1. Color Sanding Process - Color Sanding To Perfectio
    Last Post: 06-30-2010, 02:00 AM
  2. wet sanding and buffing
    By 02Sweet in forum Showcar and Detailing
    Last Post: 06-24-2009, 07:58 AM
  3. wet sanding??
    By ws6freek in forum Showcar and Detailing
    Last Post: 02-26-2009, 12:56 PM
  4. Wet sanding
    By adham in forum Showcar and Detailing
    Last Post: 01-19-2007, 12:26 PM
  5. detailing/wet sanding/etc......
    Last Post: 01-28-2006, 07:20 AM
