Results 1 to 2 of 2
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Exclamation 496 Short Block Top End Engine Build - Ground & Po
    496 Short Block Top End Engine Build - Ground & Pound
    Check out the affordable engine modifications for this Chevy 496 short block engine!Your street motor should share many of the characteristics of an MMA or UFC opponent, whether it's for the local cruise, the all-out open drag nights at the track, or even the everyday haul. And you can get the job done with off-the-shelf components. The days of super-custom engine builds with race-gas compression are all but gone in the today's street cars. Virtually every part is available over the counter, which brings the cost down, making such an engine build that much more realistic. Having the opportunity to tag along on an engine build, we wanted to illustrate how easy it is to make gobs of power.
    Photo Gallery: 496 Short Block Top End Engine Build - Chevy High Performance Magazine
    More...
    Aug 2009
    Bay Area Cali
    1995 Camaro Z28
    Very Cool!
  1. 496ci Short Block Build Up - Hotheaded
    Last Post: 10-23-2012, 02:50 PM
  2. 496ci Short Block Build - Big Heat
    Last Post: 03-26-2012, 08:10 PM
  3. 383 Short Block Engine Build - Open-Box Policy
    Last Post: 06-16-2009, 09:50 PM
  4. 402 Chevy LS2 Short Block Engine Build - Thumper
    Last Post: 10-17-2008, 06:10 PM
  5. Small Block Chevy Engine - Build Your First Engine - Tech
    Last Post: 01-30-2008, 07:50 PM
