Results 1 to 13 of 13
    Senior Member
    Toronto
    SOM
    2002 SS
    Original clutch lasting 125k miles????
    I emailed the previous owner. I dinged 200k km and am wondering if this clutch is original since everything else has been untouched. Still grabs hard and burns 2nd if I try really easy but I don't do it often
    How long do they generally last?
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    I'm at 135K on mine.
    My rearend just started whinning about a months ago on worn out street tires so the clutch obviously still works pretty good.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Quote Originally Posted by 5abivt View Post
    It varies a lot. They can almost last forever it you don't abuse them and the hydraulics are kept in good shape.
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    could last 200k or 80 like mine, my car has 76k on it and it slips sometimes when im horsin on it
    its all in how you and the previous owner(s) drove it
    Wisconsin
    2001 Camaro SS M6
    I had 76,000 on mine with about 50 track passes and it grabbed like new when I took it out. After I took it out, it only would have lasted about another 5,000 or so miles before it started slipping.
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    Senior Member
    Toronto
    SOM
    2002 SS
    Very cool to hear. I thought I might have been in for a horror story about not changing it. It does grab well and no slippage but I do hear some noises and have some more questions.
    WHen I shift between gears just moving the lever I hear what sounds like something loose in the tranny almost as if the tranny is moving with the lever.
    I hear whining from the rear also. is this a sign of anything? It pretty much always did it since I bought it. Obviously louder/quieter on or off the throttle but its always there.
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    I have 145K+ on my stock clutch, and it still grabs very well.
    `98 Formula M6 HdTp
    Shifter noise is normal as there will always be some mechanical noise as parts merge together.
    The rear end on the other hand may need some attention,
    Probably a good idea to change the trans fluid and have the rear end inspected. JMO
    i'm the other side of the spectrum... my stocker lasted about 6,000 for me...
    Aug 2009
    illinois
    2000 camaro z28
    111,500 on my original clutch.
    Still feels brand new but I baby the car
    that has something to do with it
    Aug 2009
    Californication
    2000 Camaro
    +1....it ALL depends on how u drive
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by |Vendetta| View Post
    +2
    If you drive your car like your average Civic driver and don't abuse it at all, it will last indefinitely.
    (However, as Cutlass mentioned, its imperative that the hydraulics are in good working order)
    If you drive your car the way it was meant to be driven, you'll probably get between 75-100K out of the stock clutch.
    If you abuse the hell out of your stock clutch, its probably not going to live a very long life.
    Dec 2004
    SS: NBM, tan top
    if it feels as if the tranny is moving with the shifter, i suggest you pull your console out and check the stick bolts as well as the bolts that hold the shifter to the transmission.
    Also you may want to consider checking your transmission mount.
  1. 2006 GTO - All Original 11k Miles
    By 8686 in forum Vehicles For Sale / Trade
    Last Post: 04-19-2015, 06:32 AM
  2. For Sale: '97 Cobra Convertible 37k Original Miles!!
    By Never-Enough in forum Vehicles For Sale / Trade
    Last Post: 01-24-2011, 11:32 AM
  3. For Sale: 98 Z28 BLK T-Top, M6 24,000 Original Miles MINT
    By UR2NOZ in forum Vehicles For Sale / Trade
    Last Post: 04-27-2009, 04:45 PM
  4. F/S: 02 Z28 Hardtop, 17K original miles
    By Rob Nelson in forum Vehicles For Sale / Trade
    Last Post: 10-15-2008, 01:57 AM
  5. 2000 T/A 125k miles?
    By LS1King in forum General Help
    Last Post: 10-31-2006, 03:03 PM
