Thread: Wtf?! GRRR
08-28-2009, 12:34 PM #1
- May 2007
- Davenport, Iowa
Bright Red- 1999 Trans Am Ws6
Wtf?! GRRR
I have replaced more shit on this car, I swear. Today I drove to work with heater on VENTS. It was blowing, I felt it. Switched it to defroster because of the rain. Now I can get it to blow defroster and floor but not vents. Tried AC also, it won't go to vents either. Tell me I don't have to tear the entire dash out!
08-28-2009, 01:22 PM #2
08-28-2009, 01:23 PM #3
prob not, look under the hood on the passenger's side
you should see this plastic looking thing with vacuum lines going to it, this plastic thing is like a cylinder 3/4 in diameter maybe an inch or so tall
this same problem happened to me because one of the nipples / vacuum line was leaking on this little cylinder thingy
if thats not the problem, keep searching for a vacuum leak
08-28-2009, 01:31 PM #4
Also pull the under panel where your BCM is located under the glove box. There will be a round vacuum block with multi colored hoses. Check for cracked or disconected hoses there aswell.
08-28-2009, 01:32 PM #5
- May 2007
- Davenport, Iowa
Hmm...don't they make some sort of smoke bomb I can throw in to check for leaks?
08-28-2009, 01:55 PM #6
I think what he said, when I first swapped to my ls-6 manifold I remember the instruction said to block off a line "didn't have to" and this skinny little line that hooked to the back of the intake I had plugged and then the air no longer worked it's a bitch to get to but it may be it.
it hooked in from the passenger side.Last edited by c5z28; 08-28-2009 at 02:00 PM.
vibrations grrr
By mike ciba in forum Automatic TransmissionReplies: 0Last Post: 10-18-2010, 04:49 PM -
Question: GRRR
By 2000dreambird in forum Computers / GamingReplies: 4Last Post: 08-03-2009, 01:14 AM -
My First Ticket, GRRR
By Smkn_TA in forum Almost Anything GoesReplies: 41Last Post: 04-02-2009, 09:20 PM -
engine #5... dead... grrr...
By Spaz in forum Almost Anything GoesReplies: 133Last Post: 04-02-2008, 02:06 PM -
Grrr.. motor #3 go boom need advice
By albrntout in forum Internal EngineReplies: 4Last Post: 05-26-2007, 09:29 PM
