Results 1 to 20 of 51
08-27-2009, 11:56 AM #1
- Sep 2005
- New York, NY
Collectors Edition Yellow- 2002 Pontiac Trans AM WS6
FINALIZED 454LSX build Sheet! Opinions Welcome!
Ok, so here it is, the finalized build sheet for my 454 LSX. I welcome all opinions and changes to certain parts are welcome because since im spending this much i want to get the best performance!
Estimated Completion Date: Summer 2010-2011
454cid LSX Bowtie Stroker Short Block - $6,105.00
Block: 454 Cubic Inch LSX
Litre: 7.4L
Max HP: 2500
Bore: 3.990"
Max Bore: 4.250”
Pistons: Diamond Racing Flat-Top -3.8cc
Crankshaft: Callies 4.100” Stroker Crank
Rods: Callies 6.125” LS1 Forged Compstar Rods
Main Cap Bolts: ARP LSX
Reluctor: 58x Tooth
Conversion: LS2 Kit
Note: All Forged Internals
Total Engine Airflow 245CC CNC Ported Trick Flow LSX Cylinder Heads - $2,549.00
Head: Trick Flow 245cc CNC
Bore: 4.000”
Intake Runner: 245cc
Exhaust Runner: 80cc
Combustion Chambers: 64cc
Intake Valves: 2.04”
Exhaust Valves: 1.575”
Duel Valve Springs: 1.300”
Valve Seals: Viton Canister-Style
Valve Locks: 7° Steel
Retainers: 7° Titanium
Thunder Racing Custom Grind Camshaft - $374.99
Camshaft: Custom Grind
Duration Intake: 248
Duration Exhaust: 254
Intake: .626”
Exhaust: .630”
Lobe Separation: 112.5LSA
Power Band: 2400-7500RPM
Peak: 6400RPM
Total Configuration: 248/254 - .626/.630 – 112.5LSA
Application: 6.6L (408CID) and Greater
Series: LSR
FAST LSXR™ 102mm Intake Manifold - $825.00
Fitment: 3.825” Bore or Greater
Composition: Polymer
Design: 3 Piece Modular
Intake Runner: Long
FAST Big Mouth 102mm Throttle Body™ w/ TPS - $485.00
Fitment: 102mm FAST LSXR
Throttle: Cable Driven
Composition: Billet 6061-T6 Aluminum
QTP 1 7/8" High Velocity Collector Race - $825.00
Header Type: QTP Long Tube Slip Fit
Style: Race Style W/O EGR or AIR
Size: 1 7/8” Primaries
Ends: 3"
Head Flanges: Port Matched 3/8” Stainless Steel
Tubing Material: 304 Stainless Steel
Finish: High Polished Finish
Tubing: 16 Gauge .065
Collector: High Velocity Turbulence Spike
ASP Underdrive Pully - $259.99
Underdrive: 25%
Construction: Steel
Package: Crank & Alternator Pulley Set
Pully: Tall Belt Retention Walls
Track: Integral Timing Marks
Threads: Built in
Melling Oil Pumps - $139.99
Volume: 15% + Flow
Pressure: 10 PSI Higher Pressure Relief Setting
Spring: Stock Spring Included
Design: Improved For Max Volume
Blueprinted: Yes
JP Double Roller Timing Chains - $99.95
Chain: Double Roller Heat Treated & Nitrated
Timing Adjustment: Advance or Retard 8 Degrees
Sprocket: Adjustable 9 Keyway Crank Sprocket
Spacer: 2 Oil Pump Spacer Plates
Harland Sharp Rockers - $495.00
Assembly: Needle Bearing Full Roller Fulcrum
Shaft: .250 Diameters
Connector: Duel Rocker
Packet: All 8mm Grade 8 Socket Head Cap Screws & Pedestals
Procharger F-1C 98-02 F-Body 8-Rib Race - Own
Head Unit: F-1C
Volute Diameter: 9.75”
Max Supercharged HP: 1225
Base HP Range of Motor N/A: 300-550
Max Flow (CFM): 1850
Max Boost (PSI): 38
Outlet Hose Diameter: 3”
Outlet I.D.: 2.62”
Max Impeller RPM: 74,000
Internal Step-up: 5.40:1
Self Contained/Reverse Rotation: Yes
Oil: 6oz.
ATI Completion Blow Off Valve - Own
Valve: Open
Type: Race
Construction: Steel Flange
Meziere Electric Water Pump - $639.99
Flow: 20% Increase
Volume Separation: Equal Flow to Both Cylinder Banks
Construction: Steel High Polished
Type: Electric
FAST 60 lb/hr High-Impedance Injectors - $514.80
Pound: 60#
Flow Rate: 630cc/Min
Impedance: High
Flow Matched: Yes
Pintle: Precision Ground
Spray Angle: Wide
Magnetics: Super Polar
Speed INC High-Flow Fuel Rails - $139.99
Fittings: 8#
Construction: High Strength Billet Aluminum
Fuel Adaptor: 3/8NPT
FAST Fuel Line Conversion Kit (w/Gauge) - $219.99
Rear Crossover Line: Yes
Main Fuel Supply Line: Yes
Conversion: Factory 3/8-inch Fuel Line to -6AN Lines
Aeromotive Eliminator Series Fuel Pump - $479.99
Pump: EFI 1200
Max N/A HP: 1600
Max Supercharged HP: 1100
Flow: 35% Increase Under Pressure
Pump Flow P/Hr: Exceeds 800lbs. per hour @ 13.5 Volts & 45 PSI
Inlet Port: -12AN
Outlet Port: -10AN
Pumping Mechanism: Duel Chamber
Aeromotive Billet Pump Controller - $333.55
Stage: 2 Step Pump Speed Control
Activation: RPM Activated
Voltage Control: Yes
FPSC: Minimizes Hot Fuel Handling Problems
Race Fuel Pressure Regulator - $99.99
Fuel System: EFI
Range: Adjustable From 25PSI-75PSI
Top Port: Feed Line
Bottom Port: Bypass
Fuel Pressure Rise: 1:1 Ratio
Flow Port/Return Port: 3/8th NPT
Race Fuel Filter - $59.99
Construction: Stainless Steel
Fittings: -10AN
Magnet: Powerful Polarized
Hypertech 160 Degree Thermostat - $49.99
Thermostat: 160 Degree
Housing: Aluminum
Lingenfelter 100mm MAF Sensor - $299.95
Construction: CNC Machined Aluminum
Outer Diameter: 4.00”
Length: 4.00”
Calibration: Custom Tune Via Software or Dyno
Fast Toys 104mm Air Lid - $169.99
Feature: Power Bulge Design
Size OD: 108MM
Volume: 27% Increase
Fitment: Lingenfelter 100mm MAF
Griffin High Performance Radiators - $463.99
Flow: 18% Improvement
Construction: Aluminum
Flow Rate: < 500Lt. p/min Max
Accel LSX Truck Coils - $497.92
Turns Ratio: 52:1
Primary Resistance: .2 OHMs
Secondary Resistance: 3.1K OHMs
Inductance: 5.8 mH
Maximum Voltage: 50,000 Volts
Peak Current: 160 mA
Spark Duration: 1400 uS
Weight: N/A
Thunder Racing Coil Pack Relocation Kit - $209.99
Wire Diameter: 10.4 mm Wire = .409 Inch Diameter
Core Resistance: 50 ohms per foot (+/- 20%)
Length: 12”
Wire Construction: Three Layers of Pure ZIMPLEX Silicone
Heat Rating: 600 Degree Heat Protection
Inset Construction: Tightly Woven, Heat Treated Fiberglass Braid
Boot: Pure Silicone "Pro Boot" Bonded to Wire
MSD Ignition System - $279.99
Spark: 6x Multiple Sparks
Ignition Timing: Up to 9 Degrees
Step Retard: Up to 18 Degrees for Nitrous
Boot Retard: .1° to 1.9° per Pound of Boost
Electrical System: 12-18 Volt
NGK Spark Plugs - $29.99
Type: Iridium IX TR-6
Tip: Fine Iridium
Construction: Laser Welded & Trivalent Metal Plating
Dimensions: 0.6mm
Gap: .035
Heat Range: One
Application: Supercharged, Nitrous, High Compression & High HP Engines
(Engine Only)
Goal RWHP: 585
Goal RWTQ: 550
(With F-1C @15PSI)
Goal RWHP: 850
Goal RWTQ: 750
-Anything over these numbers and ill be extra happy!!!
Total Cost: $16,455.96
Labor: $0 (Me and Friends Doing All The Work)
Seamen Wasted From Driving a 02 WS6 With a 454: Countless
Thrills and Happiness for Years To Come: PRICELESS
NOTE: This project will take an estimated 2 years to complete. All the suspension parts will be added to this list later on as the build progresses. I have an inital $20K to start the project and will be accumulating throughout the build life of the new engine.
*I WOULD LIKE ALL SERIOUS OPINIONS to weather or not the parts are good for the engine build, will yeild the BEST performance and will compliment eachother.
Thank you very much in advance and i look forward to reading everyone's opinion!Last edited by NeeD4SpeeD; 08-28-2009 at 10:02 AM.
Bulletproof Performance
2002 Trans AM WS6 M6 Collectors EditionLSX 427 F-1R Procharged Build Underway
Estimated Finish Date: Summer 2012-2013
08-27-2009, 12:52 PM #2
- Feb 2006
- U. S And A Greatest country in all of world
Stock- 2002 Camaro
i thought you couldnt use that new 102MM intake with the LS1 style heads?
08-27-2009, 01:00 PM #3
- Sep 2005
- New York, NY
hmmm, not 100% sure of that. If anything i could always go with RHS LQ9 heads or the PRC 265cc LS7 LSX heads. I think ETP makes LS7 heads at 265cc also. Either way the flow numbers are pretty much the same so i wouldn't be sacrificing anything....
Im going to look into that tho thank you!Last edited by NeeD4SpeeD; 08-27-2009 at 01:05 PM.
08-27-2009, 01:08 PM #4
- Sep 2005
- New York, NY
Sorry that head info is incorrect i just noticed it.
These are the correct ones:
245cc Flow Data
Intake Exhaust
0.1 69 56
0.2 146 130
0.3 237 201
0.4 294 249
0.5 336 269
0.55 348 273
0.6 353 276
Tested on 4.185" bore @28"
And these are the PRC LS7x 265cc 7.0L CNC Heads i was considering also
Flow Data: @ 4.125" Bore Plate Superflow 600
LS7
Intake
LS7 Exhaust PRC 265cc
LS7 Intake PRC LS7 Exhaust
.200 161 114 169 119
.300 227 171 248 179
.400 291 193 308 211
.500 330 203 351 224
.600 351 209 383 235
.650 353 204 388 241
.700 353 209 393 246Last edited by NeeD4SpeeD; 08-27-2009 at 01:13 PM.
08-27-2009, 01:22 PM #5
- Feb 2006
Stock- 2002 Camaro
sounds like it going to be a bad ass build
08-27-2009, 02:10 PM #6
08-27-2009, 03:32 PM #7
So you only expect to make 585rwhp w/ this combo? I'm pretty sure you could make that w/ the 454 alone let alone w/ the F1. More like 1000rwhp, probably more than that. For that kind of power I would think you'd need waaaay bigger injectors if it's anywhere close to what I think it could make.
08-27-2009, 03:57 PM #8
- Sep 2005
- New York, NY
Well, i was thinking the engine alone with the supporting bolt-ons would net somewhere around 600RWHP/TQ. With the F1C at a reasonable 12-15PSI i probably could make 850+ but then i would need a DFi and all that other crap which i was really hoping to aviod but hey, if you wanna make BIG power, better be prepared to pay BIG bucks!
And i edited the Build Sheet estimated HP/TQ thank you!Last edited by NeeD4SpeeD; 08-27-2009 at 04:03 PM.
08-27-2009, 04:07 PM #9
Injectors are probably going to be too small. Even for the 454, add the F1, I cant help but think a 60 is way too small.
Did you tell the engine builder that this is going to be a FI build? What compression ratio are you aiming for, and what did they say this combo is going to produce?
Why the LS2 conversion with 58X relucter wheel? This is going on a TA right?
Double roller is still causing people problems. The LS2 chain is good for most people, probably not for this build. Ask around for different chains. I know a sponsor at the other site had some real C5R chains. There was also anothr chain I cant remember the name of. It was very pricey, but had a great rep and would get you away from the double roller.
Have you ran this entire combo, plans, and end result goal over with the engine builder? They are the ones that should be telling you what to do in this situation. Most of us have not done such a build, and are probably not qualified to give thier opinions here. Myself included.
08-27-2009, 04:46 PM #10
- Sep 2005
- New York, NY
Yes, your right the injectors are too small, i found some 96# injectors but there low impediance and i really want high. Figured the 96# would be sufficient for the build because the whole fuel system (lines included) are rated to 1200hp.
I talked to the builder and he said for a FI setup he was looking for the CR to be approx 8.5:1 or 9.5:1 to be able to handle a decent amount of boost, nothing crazy.
I was told from TSP that the LS2 conversion and the x58 reluctor was necessary for the swap, never really gave it much thought or questioned it. He did give me an answer but i dont remember the answer.
I have the double roller on my car now. Granted it's only making 450RW but i'll look into the C5R one.
I am working closely with the engine builder (my friend) and figured i would go on this board to get other alternatives to some parts i've listed to replace them for better ones i.e. the double roller for the C5R (thank you BTW) So just gathering opinions then i go running to look for the part at the best price and will SLOWLY lol start assembling pieces of the engine.
I know thata most ppl on here may not be the best qualified for such a different build but they have a unique knowledge of the LSX cars and hi-performance parts to go with them and that's why i'm asking so i dont make a mistake and everything goes as smooth as possible the first time
So thanks pal for your opinion i will look into the C5R and if you have the name of the person or website that sells the real ones please message me!
08-27-2009, 05:23 PM #11
Alright, for the C5R chain, look up Katech. Pretty sure they are right down the street from me.
The other chain I was thinking about is the Cloyes Hex-Adjust with the IRL chain sold by Skoggins. Call SOON. They were limited production, and they were selling off the last few sets quite some time ago. If you can get your hands on that, its the best chain, timing set available known to my reading abilites.
08-27-2009, 05:45 PM #12
08-27-2009, 05:52 PM #13
08-27-2009, 05:57 PM #14
Look into that other chain also. Compare the two prices, and do some research on the two. Awhile ago, some knock off C5R chain were being sold, Katech is a trustworthy source.
08-28-2009, 09:44 AM #15
08-28-2009, 09:50 AM #16
- Jan 2006
- Shepherd, Michigan
why the slp oil pump ? why not look into melling oil pumps..i wouldn't trust slp's oil pumps at all.
08-28-2009, 09:53 AM #17
- Jan 2006
also i wouldn't worry about changing your coils..the ones on our cars should be able to handle anything you throw at it ..within reason. and also..keep a eye on your fuel pump..i would go dual just for safety ...
08-28-2009, 09:54 AM #18
- Jan 2006
i might be missing something..but i dont see anything addressing cooling
08-28-2009, 09:56 AM #19
08-28-2009, 09:59 AM #20
Question: Build Sheet?
By 2000dreambird in forum GM TrucksReplies: 5Last Post: 10-20-2011, 04:36 PM -
LSX 454 Build Sheet and Opinions
By NeeD4SpeeD in forum Internal EngineReplies: 53Last Post: 09-09-2009, 02:14 PM -
Build Sheet
By HUNTNFISH in forum Firebird / WS6Replies: 26Last Post: 06-27-2009, 10:50 AM -
Build Sheet?
By tbirdsc44 in forum Classic MuscleReplies: 13Last Post: 01-14-2007, 12:56 PM -
Mod Build Sheet
By Sarge in forum GTOReplies: 11Last Post: 02-23-2006, 02:04 PM
