    Jul 2009
    Lawrenceville GA
    1999 Trans Am
    unplugged my computer !!!
    i unplugged the computer on my 99 ws6 to get under it,well when i plugged it back in and started her the engine light came on.now the low idle code is popping and of course its idling low what the heck ???
    Same effect as unhooking your battery. The PCM has to re-learn a few things before it will steady out. As to your lights, is the harness plug fully seated in the PCM?
    Jul 2009
    Lawrenceville GA
    1999 Trans Am
    i think i got them in nice and tight but i will recheckem.
    have the code read at a parts store (free) and see what the code is and then go from there. Could be a number of things. Check all wires and make sure you didn't leave something unplugged or something along those lines.
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    you didn't pull it's harness and replace it with the battery still hooked up did you?
    Jul 2009
    Lawrenceville GA
    1999 Trans Am
    Thanks everyone. like pajeff said the computer relearned itself. I got advance auto to clear the code and it still hasnt come back.
  1. idle issues... idle high. unplugged tps runs good?
    By okiels1 in forum Firebird / WS6
    Last Post: 12-31-2016, 03:36 AM
  2. Question: Better idle with Mass Airflow Sensor unplugged
    By Blue2KTA in forum General Help
    Last Post: 04-23-2012, 05:50 PM
  3. Alice in Chains MTV unplugged
    By onetroubledguy in forum Almost Anything Goes
    Last Post: 03-27-2009, 11:26 AM
  4. car idles better with tps sensor unplugged
    By occamaroz in forum Computer & Tuning
    Last Post: 11-03-2007, 03:09 PM
  5. Replies: 10
    Last Post: 10-29-2007, 03:50 AM
