    Aug 2009
    long island
    1999 pontiac trans am
    Question QUESTION: Heated Oxygen Sensor P1133 OBD Code
    Need some help guys...I recently put in Edelbrock headers and a new exhaust system for a 99 Pontiac TA. the check engine light came on, the OBD II code reads P1133 - heated oxygen sensor bank 1 (rear).
    being it happened one day after installing the headers, what could it be? throttle body? mas air? need a little help here. just starting out. i don't just want to put a new sensor on, for it to happen again.
    anyone got any ideas?
    thanks,
    eric
    Bragg NC
    Met. Sunset Orange
    01 SS
    Im guessing you put on shorties, and kept the cats? Check your 02 wiring, ensure none of them are burnt or melted. Any exhaust leaks befor the 02's? Try swapping the sensors and see if the code follows, if it does then your sensor is shot if not then it may have just had a hiccup with the new exhaust.
    Aug 2009
    long island
    thanx for the info. going 2 check it out 2day. ur absolutely right, shortys & kept the cats. changed the exhaust system as well at the same time.
    thanx
    eric
    The O2 sensor has a heater element in it and they sometimes go bad. Generally, the heater wires are the same color and you simply check for continuity across the wires after unplugging the connector. If the sensor tests "open" and has no continuity then the heater element is bad. For more info, and a handy wire color code chart, check out: http://www.boschautoparts.com/NR/rdo...sorInstall.pdf
  1. more oxygen sensor help
    By 2002 in forum General Help
    Last Post: 08-21-2016, 06:17 PM
  2. NEW O2 Sensor, getting P1133 DTC ????
    By jfl330 in forum Computer & Tuning
    Last Post: 07-11-2011, 08:04 AM
  3. 01 SS p0135 code-heated o2 sensor!
    By meadowz06 in forum General Help
    Last Post: 10-06-2010, 05:16 PM
  4. Oxygen Sensor
    By NJ2002WS.6 in forum General Help
    Last Post: 09-04-2008, 04:09 PM
  5. Oxygen Sensor turned red
    By RV7LS1 in forum General Help
    Last Post: 06-26-2008, 02:06 PM
