    non-LS1 question....97 Sonoma ABS
    Anyone ever bled the ABS system on an older sonoma with a tech 2? What I've gathered is that the tech 2 just cycles the valves releasing the air and that the ABS does the same thing on start up as a test. So I'm wondering if I can just bleed the brakes a time or two to get that air out of the ABS block?
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Was the master off the truck or run dry?
    Quote Originally Posted by bigrondownhiller View Post
    it was run dry.
    Feb 2006
    Orange County, NY
    always dirty
    I have read that people have just bled them on other cars without the tech 2. I just read my camaro manual and it says there are bleed screws on the modulator. Does the sonoma have them?
    not really...it has a couple of valves that I'm not familiar with. Supposedly when they use the tech 2 to bleed them they're just cycling the valves in the abs block to release the air. I've read that the valves cycle on start up which is doing basically the same thing. I need to figure out how/what those valves are because my manual says something about bleeding them via those valves but it takes a special tool evidently to depress the valves.
    Feb 2006
    Orange County, NY
    always dirty
    You probably need the tool then. That way you can cycle each valve for each individual wheel.
  1. Sonoma Pics
    By c5z28 in forum Western Members
    Last Post: 06-17-2009, 05:37 AM
  2. For Sale: 2003 GMC Sonoma $6,500
    By Benner in forum Vehicles For Sale / Trade
    Last Post: 03-15-2009, 01:52 PM
  3. For Sale: 1994 GMC Sonoma
    By Y2K_CAMARO in forum Vehicles For Sale / Trade
    Last Post: 09-13-2008, 09:11 PM
  4. 1997 Gmc Sonoma Ext Cab
    By Quick5O in forum Vehicles For Sale / Trade
    Last Post: 06-13-2008, 05:07 AM
  5. JPM wins at Sonoma!
    By astyles in forum Almost Anything Goes
    Last Post: 06-25-2007, 12:11 PM
