Results 1 to 20 of 31
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    10" subwoofer suggestions
    after many years of service my jl audio 10" woofer is on its way out.i don't know much about woofers,so i am asking what would be the best woofer? the t/a has the factory monsoon head unit and speakers,plus a subthump stealth box,and rockford-fosgate amp (not sure how many watts the amp pushes).thanks.
    St. Peters, MO
    2001 WS6
    I had a Memphis Audio dual voice coil 10" in my last setup and it sounded pretty good. I hated the JL in the stealth box and got rid of it pretty soon after I got it.
    UNC Charlotte
    2000 Chevrolet Camaro Z28
    i have a JL Audio 10W1 v2 in the stealth enclosure....sounds great...costs around $119
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    thanks,i looked at crutchfield earlier and found out how little i know about car audio,there were 2 ohms 4 ohms dual voice coils and ect.i was lost as hell.do know JL makes damn fine speakers,though.
    IL
    1999 Trans am
    I have heard a few different ones in a 4th gen. Right now I have an RE audio 10'' in a stealth box that I would never change. Alpine type R, Infinity Kappa Perfect, and a JL w3v2 all sound stellar as well.
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    Lightbulb
    You can't go wrong with any of these.
    Image Dynamics IDQ 10.v3 and IDMAX10.v3, Fi SSD10, Fi Q10
    Northern Virginia
    BLACK
    You need to make sure the sub matches well with the amp. For example, if you get a dual voice coil 4-ohm sub, that means you'll need to connect the 2 voice coils in parallel (2-ohm load) or in series (8-ohm load). If your amp works best with a 4-ohm load, you wouldn't want a DVC 4-ohm sub.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    Quote Originally Posted by mbrownin View Post
    thank you,but i have no clue what you just said,lol. i'll look at the amp and the sub tomorrow and give some more information for y'all to work with.i do appreciate your expertise,though.
    Member wenn_du_weinst's Avatar
    Aug 2008
    South Dakota
    I do sound competitions so if you need any help pm me if I forget to check this thread again I'll let you know what you need to look for to match your amp
    UNC Charlotte
    Quote Originally Posted by BLHS99LS1 View Post
    i agree the JL w3v2 sounds great...but for the stealth enclosure for f-bodys, the w1v2 sounds better...not as loud...but way better sound quality- at half the price....i had the w3v2 in my z28 w/ the JL 250/1 ....w1v2 sounds better IMO....w3's need more air space....ported if possible to sound its best....the w1 was made for small enclosures.
    LSwut tep98ws6's Avatar
    Jun 2009
    Saint Louis, MO
    Arctic White & Black
    '98 WS6 M6 - SWAPTIME!
    I have an Alpine Type R 10" and it's awesome - sounds great at every level. If you're concerned about $$ ... try to find an '07 or '08 Type R, I got an '07 model in '08 for $90 from an audio shop. Definitely worth every cent you spend
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    i have heard good things about the alpine type r.i have some type s speakers in my sail panels,and they are very good.hard to go against a JL though.
    Aug 2008
    South Dakota
    I have had type r's and jl w3 jl w6 jl w7 with many other subs I would spend your money on something different look at these they sound absolutely amazing
    http://www.woofersetc.com/p4992/ID10...-Subwoofer.htm
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    subwoofer= JL audio 10w1-4....amp= rockford-fosgate punch 45.2...i'm sure amp is at least 10 years old sub is probably about 7 years old.
    The Coffee Shop
    Red Jewel
    2010 SS
    If you liked your old JL...then pick up another......if the amp is 2 ohm stable you could get a 4 ohm dual voice coil sub. Either the JL w1 or JL w3 will suit your needs.
    Aug 2008
    South Dakota
    amp is stable to 4ohms bridged you want a dual 2ohm or a single 4ohm sub
    UNC Charlotte
    Quote Originally Posted by 02transamce View Post
    JL Audio 10W1v2 4ohm model would be excellent in f-body with said amplifier.
    Member izzhemp's Avatar
    Osawatomie KS
    white/Black
    1999 Pontiac Firebird
    if you want great clarity and bass id go with an Alpine Type X, Diamond audio is also good i use there amps.
    Nov 2008
    Montgomery,Ala
    2007 Corvette
    Ebony
    Quote Originally Posted by wenn_du_weinst View Post
    i looked at the subthump website and that image dynamic sub was one listed as "suggested for best performance".price is right too.thanks for linking that website,their prices seem to be a bit lower than crutchfield.
    Aug 2008
    South Dakota
    no problem thats one of the best sounding subs available for that price range
  1. 12" Pioneer Subwoofer DVC - $40
    By 94 Formula in forum Western Members
    Last Post: 01-31-2010, 06:55 AM
  2. Lowest Frequency 10" subwoofer
    By gfeller2006 in forum Stereo and Electronics
    Last Post: 11-06-2008, 11:36 AM
  3. "Planetary gearset noise".. Ideas or suggestions?
    By emarkay in forum Automatic Transmission
    Last Post: 02-23-2007, 05:59 PM
  4. Audiobahn 12" subwoofer F/S
    By dkishton1486 in forum Stereo and Electronics
    Last Post: 03-28-2006, 03:53 PM
