Results 1 to 17 of 17
Thread: headlight restoration
08-14-2009, 11:17 AM #1
bought meguiars plastx and wanted to try and fix my headlights a bit from what they were... figured i'd share with you guys how it came out
all i did was buy the $7 bottle and use paper towels for a half hour...
most of the headlight looks good but there are some spots that were stubbord to get off.... i'll get at it later
Before:
After:
Other side After(forgot to take a before for the other side):
08-14-2009, 11:34 AM #2Junior Member
- Baltimore Maryland
Red- 2002 z28
yea it looks a lot better,, I wonder if you used a buffer or power drill with some sort of attachment , it would come out cleaner
08-14-2009, 11:35 AM #3COTM July '09
- Jun 2008
- Annapolis, MD
BLK/BLK w/CGM Stripes- 2010 Camaro 2SS/M6
I wet sanded my headlights ... 600, 1000, 2000 then polished it with swirl and haze remover and a coat of polish/wax to seal it up
08-14-2009, 11:37 AM #4COTM July '09
- Jun 2008
- Annapolis, MD
08-14-2009, 11:51 AM #5
I used an electric power drill with a power ball on mine(really have to fall asleep to worry about heat). The bitch with sandpaper is if you rub it to rough it takes forever to get the deep scratches out over just the oxidation. There is a plastic company that referred me to a polish they have so as to not use sandpaper, next time I get some unsanded lights i'll see if there shit really works.
This is my result with sandpaper then powertool polishing with meguiars plasticx.
http://www.ls1.com/forums/album.php?albumid=123
keep it up op.
08-14-2009, 12:05 PM #6
Turtle wax rubbing compound with a buff pad on my drill. Then Polishing compound. Sealed with liquid Ice wax. Worked good.
Mine had a bit more haze than yours but you have pretty good results for just using paper towels.
Plastx looks worth a try.
Masking tape around the headlight on the paint and seal help with cleanup.
08-14-2009, 02:28 PM #7
I wet sanded mine. Here's before and after.
08-14-2009, 02:44 PM #8This Light Dinner Is Over
- Jan 2007
- Hamburg, Germany
Silver- 1998 Camaro Z28 A4
how do you guys get your headlights that blind in the first place?!? mine are crystal clear, after 100,000 km!
08-15-2009, 12:52 AM #9
California sun?
08-15-2009, 01:03 AM #10
08-15-2009, 01:12 AM #11
......... I dunno then. haha. Do you keep yours in a garage? because mine's outside 24/7.
08-15-2009, 01:35 AM #12
08-15-2009, 01:55 AM #13
08-15-2009, 08:56 AM #14This Light Dinner Is Over
- Jan 2007
- Hamburg, Germany
7 miles would be around 11km, correct. my point is that upstate NY means freezing winters, meaning salt on the road. the headlights get pretty warm, salt burns into the surface. being near the sea means salt in the air. sun burns it in.
i wonder if people in - say - kentucky or tenessee don't have these problems?
08-16-2009, 08:28 AM #15
hahaha yeah i live in the binghamton area of new york, little south of syracuse.. my headlights were this bad cuz the guy i bought it from totally neglected the car
so i'm trying to get it back to how it should look haha..
thanks for the comments
08-16-2009, 12:27 PM #16
The headlights were pretty beat when I bought that particular vehicle. Its a 4x4 for the bad winter days so I wasn't concerned about the looks. After I had it a while I figured out that the lights were dim, so I fixed the problem.
It had 110,000 miles on it when I bought it, a lot of then hard miles as I have learned.
08-17-2009, 04:29 PM #17
ive been fighting this for a while now. best solution is the 3M kit. it has a polish and sealant. sand the light with a mini da so the scratches arent visible. the kit has 500, 800 1200 1500 and 3000
BG headlight restoration kit with pics
By WICKEDLS1 in forum Showcar and DetailingReplies: 15Last Post: 02-24-2011, 10:34 AM -
Headlight restoration (pics)
By GoFast908Z in forum Showcar and DetailingReplies: 6Last Post: 04-05-2010, 06:00 PM -
Headlight Restoration
By LS1Jason in forum Showcar and DetailingReplies: 12Last Post: 04-14-2009, 03:53 PM -
Headlight Restoration Kit
By LETHALxLS1 in forum Showcar and DetailingReplies: 19Last Post: 08-17-2007, 09:15 PM -
Headlight restoration?
By SailorZ28 in forum Appearance SectionReplies: 2Last Post: 03-28-2006, 07:41 PM
