Thread: fog lamps
08-11-2009, 03:27 PM #1Member
- tx
pewter- 99 trans am ws6
fog lamps
anyone running 100 watt fog lamps in their car. should i just stick with the lower wattage (30 watts). will the 100 watt bulbs melt the housing?
08-11-2009, 03:51 PM #211 years of bangin gears
- Jan 2009
- North Jersey
Will melt the housing and lenses. I ran 100 watters in my Beretta GTZ. The lenses were glass. A week after I installed the 100 watt bulbs, the driver side lens cracked and the week after that, the pass side lens cracked. The wires were burned as well. If 100 watt bulbs can generate enough heat to crack glass, imagine the damage they can do to plastic. You could probably get away with 45/55 watt bulbs, but that is the limit IMO.
08-11-2009, 04:24 PM #3Member
- tx
thanks, i'll just keep the stockers
08-11-2009, 05:05 PM #4Junior Member
- Aug 2009
- Bay Area Cali
White- 1995 Camaro Z28
I dont understand why they even make 100 watt fogs.
08-11-2009, 05:20 PM #5
08-11-2009, 05:32 PM #611 years of bangin gears
- Jan 2009
- North Jersey
Try Sylvania SilverStars. 880ST for the fogs. I have SilverStars in my fogs and I am quite happy.
08-11-2009, 05:48 PM #7
i run bulbs that are a bit higher wattage then the stockers and have not had a problem. I want to say that they are only about 10 watts higher.......100watts will most definitely ruin your housing and harness etc, with the possibility of causing other electrical problems due to the melting
Fog Lamps
By SOCAL WS6 in forum Firebird / WS6Replies: 4Last Post: 01-03-2009, 10:21 AM -
fog lamps
By txz28 in forum Camaro / SSReplies: 1Last Post: 08-17-2008, 12:26 AM -
Help: Having problems with my fog lamps
By KING Z28 HAWK in forum Stereo and ElectronicsReplies: 7Last Post: 02-27-2008, 03:36 AM -
fog lamps blues
By bmwmteam in forum Firebird / WS6Replies: 12Last Post: 09-04-2007, 03:54 PM
