Thread: Upgrade path
08-06-2009, 08:33 AM #1Chief of his tribe!
- Mar 2008
- NYC
Navy Blue Metallic- 2000 T/A Firehawk M6
Upgrade path
OK so i've been reading these threads on how universally hated the OEM rears are. As a result I don't want to put even 1 dime into repairing or replacing parts in mine. I've had the car all of one month and change and have already started doing the base mods i'd need to support a good all round performance combo.
I already installed KYB AGX's all around and have UMI 3 point SFC's and UMI STB on the way.
The next step in prepping the car for a perfomance life is something that eludes me. I know that a rear is coming but how soon is anyone's guess. From reading around here and other places it seems like a lot of people like the Strange rears. so at the moment I feel like I am leaning towards a rear from them. I don't know whether I should be eying the 9inch or 12 bolt so i'll pose that as one of my questions.
At the moment my rear seems to have a bad bearing and a leaky pinion seal. I'll probably change out the fluid to keep it humming along for now but I'm not really concerned about it blowing up on me. If it were to do that i'd just put it in the driveway and go ahead and get the rear. I'd prefer to wait till I had the cash on hand but it wouldn't kill me if I had to order sooner.
Assuming the rear stays in one piece we have finally reached my conundrum. After the SFC's and STB are installed would I be better served buying a torque arm relocation bracket and bushing and rear LCA's or is it not worth it till I have a new rear and am making serious power. I would like the car to be as much of a corner carver as is possible with an Fbod while still throwing down decent numbers on the strip. It will likely be some time till I can afford to make that kind of power since buying a home comes first and suspension seems to be cheaper than horses.
Finally when I do get the rear what gears would be best for autox/drag duty while still maintaining decent highway performance. I was thinking of 4.10's or 4.30's since it seems like even with 4.30's i'd be chugging along nice and low in the RPM's at the local 50-60mph flow of traffic.
The car is NOT a DD. I have a neat lil go-kart of a Saturn SC2 for that.
Thanks all.
08-06-2009, 05:40 PM #2
Well the stock rears are ok for mild hp automatics. guys run 300 up to 500 on a stock rear with no problem ON THE STREET. track time, 6 speeds and stickey tires seem to gut these things. I see your a 6 speed so a good bet would be a 9incher for you. Watch what mods you do first cause some will not transfer over to the 9 inch or 12 bolt houseing with out all new pieces or adapters. If you plan on going to the strip soon I would save up and get the rear in the car.
08-07-2009, 10:25 AM #3Chief of his tribe!
- Mar 2008
- NYC
I've already seen the order forms that require you to specify axle... which is why I want to plan this out. I'd hate to spend twice what I could have spent once.
Any particular advantage in a 9 inch over a 12 bolt? I had been eyeing a 12 bolt Strange with 4.30's and all the ABS nonsense pre installed. My mind is malleable on this so if there is something I don't know that will shift me to the 9 inch please enlighten me.
08-07-2009, 10:38 AM #4
I have read in threads in here and on LS1tech of people blowing up the 12 bolt. Not to say that the 9" cannot be destroyed, but this is what I have read. The 9-inch locates its pinion gear lower on the ring gear to improve tooth contact. This strengthens the rearend assembly but at the cost of approximately 2 to 3 percent loss of power to drive the gears compared to a 12-bolt.
Most people in here I believe would tell you to go with a 9" with a M6. I did with 4.11 gears and I love it.
Also, I would suggest getting the relocation brackets and LCA's while you are at it. It makes a big difference.
Good luck.Boost gets you laid, unless your name is Jon.
08-07-2009, 10:48 AM #5Chief of his tribe!
- Mar 2008
- NYC
wow not much in the way of power mods on that SS. basically a lid an full exhaust eh? with all the chassis and drivetrain mods what kind of ET's are you running with that car? I'm more interested in Chassis and suspension at the moment so a little insight into what can be gained would be nice.
Magnaflow cat back, adj KYB's, 3 point SFC's, STB, LCA reloc, adj LCA's, SLP lid, Fernco bellows, Strano Springs, Drag Bags, Tick adj Master cylinder, Monster stage3 clutch, speed bleeder, Billet flywheel, MGW shifter, !CAGS
08-07-2009, 10:56 AM #6
Haha, at a good dime too! I just got all this in the past 3 months. I haven't been able to get to the track yet. I plan on it though within the next month hopefully. The car is getting the trans built/shifter/clutch right now. Also will have it DYNO tuned before the next week and a half.
I'll definitely let you know what times I get. I can tell you that my car handles 100% better now. No more wheel hop, no more of the ass end getting squirly during power shifting. Even when I get on it in a turn the car forces itself to go straight.
And don't worry about engine mods, haha. Those are on the way. I wanted to build everything else first though, which I believe is the right path to take. In the end, she'll have a D1SC and hopefully making somewhere in the neighborhood of 500rwhp. I need to replenish my funds for a while before that happens though.
08-07-2009, 12:58 PM #7Chief of his tribe!
- Mar 2008
- NYC
Yeah I want to get a D1SC as well but yes that is likely years away as a house comes first. and before the D1SC i want a built Texas Speed LS3..... of course by the time I can afford it I may be looking at a Gen V block with DI and VVT
In all seriousness that is the next small block and that would take my head right out of supercharging and make me give a good long look at a good turbo setup.
08-08-2009, 12:21 AM #8
As he said, Most M6 guys are going to go with the 9 inch and most auto guys go with the 12 bolt.
M6 launch at the strip causes huge shock and the 9 inch seems to take it were as the auto's don't have the drive line shock when they leave the line. If you search the forum there was a coversation about 9 inch V's 12 bolt no more than 6 months ago.
08-09-2009, 05:31 PM #9
Strange 12 bolt here with M6. I launch it on slicks from 6,500+, so far so good. If I were to do it over again I'd go 9 inch for peace of mind. You'll also want to buy a chrome moly or steel drive shaft as well. I'd skip the torque arm relocation mount. I keep mine (full legnth) mounted right on the tranny, again so far so good.
08-10-2009, 12:40 PM #10Chief of his tribe!
- Mar 2008
- NYC
9 inch peace of mind eh? I hear mounting the pinion lower, as was said is the difference between the 12 bolt and 9inch, helps with running quieter as well? Could be a win win. better contact from the lower pinion and reduced driveline noise? i guess i'm suddenly seriously considering the Strange 9inch unit now. any thoughts on diff's? Auburn Torsen etc? I'm pretty sure the 4.30 range is where i'm going to end up gear wise. I rarely drive over 70mph so the rpms won't be too bad in 6th. Of course before I actually drop any coin on this i'll do all the appropriate calculations.
08-10-2009, 02:06 PM #11
08-10-2009, 07:33 PM #12
yea check out moser for the 9inch.
Good thoughts going out to those in the path of tornadoes!
By KahanaReef in forum Almost Anything GoesReplies: 9Last Post: 05-21-2013, 02:38 PM -
How Sandy's Path Could Chart A Course For Romney's Victory
By Ed Blown Vert in forum Political / Debate ForumReplies: 0Last Post: 11-05-2012, 06:30 PM -
There is but one path, we kill them all.
By MacGyver in forum Almost Anything GoesReplies: 7Last Post: 04-18-2010, 09:59 AM -
1997 Firebird Formula- what's my upgrade path?
By jedimaster in forum Firebird / WS6Replies: 7Last Post: 09-06-2007, 03:34 PM
