Results 1 to 11 of 11
Thread: Drill Mod?
02-04-2006, 04:00 AM #1
- Jan 2006
- Charlotte, NC
Black- 1998 Camaro Z28
Drill Mod?
I was searching around and some people were talking about a drill mod on 98-02, I derived it relates to the slave cylinder. I did a search and didn't really find much information on it.
What is the problem? What is the drill mod exactly?
Is this something I should be considering doing for my 98?
02-04-2006, 11:59 AM #2
- Jul 2005
- Jacksonville, FL
http://www.ls1camaro.net/sections.ph...rticle&artid=1 Also at www.installuniversity.com as part of a master cyl R&R w/a couple pics. Don't know how much it helps (A4 here) but a couple people I know have done it.
02-04-2006, 03:10 PM #3
- Sep 2005
- New York, NY
Collectors Edition Yellow- 2002 Pontiac Trans AM WS6
If you have a 02 WS6 you dont need to do the drill mod because GM fixed the prob right?
02-04-2006, 03:48 PM #4
- Jan 2006
- Charlotte, NC
Thanks!
02-06-2006, 04:45 PM #5
- Coatesville Pa
Blue- 2001 Pontiac Trans Am
Originally Posted by NeeD4SpeeD
02-07-2006, 09:21 AM #6
restrictor still there, only update was the slave
02-11-2006, 10:12 AM #7
- Nov 2005
- Cypress, Texas
Burple- 1966 427 Cobra Replica
The 1/8" bit won't go past the fitting. Do I need to drill out some of the fitting too? That won't cause any probs will it? One step smaller will go past the fitting but it didn't take much to drill it past the restriction in the line and I'm still getting funky clutch action after hard, high shifts.
02-12-2006, 04:53 PM #8
fitting ? I drilled mine out to 9/64 because my 1/8 " bit was broke
02-12-2006, 08:12 PM #9
- Nov 2005
- Cypress, Texas
Yeah, the exterior-most orifice is smaller than 1/8". From what I understand, I could certainly be wrong, the restriction is past this point, within the line. Drilling the restriction out with a 1/8" drill bit requires you also drill the orifice of the fitting out to 1/8", at least it would on my car.
02-14-2006, 11:11 AM #10
- Nov 2005
- Cypress, Texas
Anyone?
02-14-2006, 02:45 PM #11
- South NJ
silver metallic- 1998 Pontiac Trans AM
i have a 98 trans am with a spec stage 3, and a mcleod slave cylinder. i didnt do the drill mod, and after did the clutch/slave swap i dont have those problems like my old spec and stock slave. i belive the new slave has a slightly bigger bore but the master is still stock. i have no problems shifting or launching
DRL drill mod?
By ldurham in forum Appearance SectionReplies: 3Last Post: 08-22-2011, 06:45 AM -
Drill Mod help
By Chronic442 in forum Manual TransmissionReplies: 11Last Post: 05-16-2008, 12:27 PM -
Drill MOd
By SVG210 in forum Manual TransmissionReplies: 2Last Post: 02-10-2008, 07:01 PM -
Drill Mod?
By Hot Rod SS in forum Manual TransmissionReplies: 3Last Post: 07-13-2007, 12:37 AM -
Drill Mod?
By Hot Rod SS in forum Manual TransmissionReplies: 0Last Post: 07-12-2007, 01:59 AM
