    Junior Member dermot's Avatar
    Mar 2009
    Dubai
    1999 Firebird TA
    another silly question...
    Hi,
    -My 99 LS1 TA has an aftermarket temp gauge, and I noticed that it does not read the same (or even very close really) as the temp reported by my Diablo HH... ?? -The gauge reads significantly higher.
    -Are there actually 2 senders? If so, I guess I can presume that the coolant temp. reported by the Diablo is correct, the temp gauge is off?
    thanks in advance..
    Dermot.
    Quote Originally Posted by dermot View Post
    Hi,
    thanks in advance..
    Dermot.
    this could be a trans temp guage...
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Hi,
    thanks in advance..
    Dermot.
    The Diablo is getting the temperature that is reported to the PCM. It is generally accepted that what the PCM is seeing is correct. Generally
    Mar 2009
    Dubai
    1999 Firebird TA
    Okayyyy.... reported by WHAT though? Another sender? If it has a separate sender for that then I'll happily assume that the aftermarket thing is wrong/junk... (which would be good because when the temperature gauge says e.g. 100 C, the diablo says 199F... )
    -& it's damn hot out here ALL the time (Dubai) !!
    kr D.
    the temp sender is in the drivers side head above plug #1.
  1. might be a silly question but.....
    By transamdude99 in forum Firebird / WS6
    Last Post: 10-31-2010, 09:46 AM
  2. Question: Silly LS6 Intake Question
    By kool-aide in forum External Engine
    Last Post: 11-26-2009, 06:05 AM
  3. next silly question
    By dermot in forum General Help
    Last Post: 09-03-2009, 10:32 AM
  4. silly question ??
    By MSTZ TA in forum Stereo and Electronics
    Last Post: 08-19-2009, 07:34 AM
  5. silly cam question
    By RDS in forum Internal Engine
    Last Post: 07-26-2007, 10:32 AM
