Results 1 to 10 of 10
07-28-2009, 04:34 PM #1
Installed Volant, now get MAF code!
I have a stock 2002 ram air TA. Had a machanic friend of mine install a volant CAI. Shortly thereafter, check engine light came on. Checked codes, and it was a MAF code. Has anyone else experienced this? Any recommendations?
07-29-2009, 08:08 PM #2
Is everything on tight and snug. If you have a leak after your MAF it will cause that meaning you have un metered air and youll most likely run lean. Also check and clean your MAF.
08-05-2009, 07:44 PM #3
We did those things...same result. Any ideas?
08-06-2009, 09:13 AM #4
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
Bump I'm ordering one for my WS6 and don't wanna run into the same problem.
08-06-2009, 09:53 AM #5
- Jan 2006
- Shepherd, Michigan
we need to know the code ..more then likely he damaged the maf when installing ..or the connector isn't seated correctly..or make sure the maf is on the right way!...they have on the side a sticker that shows the proper flow direction
08-06-2009, 11:06 AM #6
- Jan 2008
- Waco
2005 Ram SRT-10 QC 8.3l- 1999 FRC Black
Like Shady, said and I've done it when in a hurry, make sure the arrow is pointed into the engine!
08-06-2009, 11:32 AM #7
- Jul 2005
- Jacksonville, FL
Like stated earlier post the code, could be unmetered air/car was started with it unplugged/ENG SEN fuse blown/etc.
08-06-2009, 04:21 PM #8
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
im going to order it anyway
08-06-2009, 04:43 PM #9
more than likely its just one of those things thats easily overlooked. and if you can overlook it once there is no reason why you wouldnt be able to overlook it twice. check, check, and check again. it cant hurt
08-06-2009, 05:42 PM #10
- Jul 2007
- Chicago IL
Pewter- 2000 A4 WS6
TY i'm going to do it up for sure.
Volant CAI kit???
By kenro23 in forum External EngineReplies: 21Last Post: 02-01-2012, 05:50 AM -
Question: Volant CAI for Z28, anyone have this installed?
By davidz28 in forum External EngineReplies: 21Last Post: 10-30-2011, 06:47 PM -
volant ram air kit
By 04gtochevynovaguy in forum GTOReplies: 4Last Post: 08-16-2011, 04:15 PM -
Jet Hot LT installed--SES code
By swifty in forum External EngineReplies: 18Last Post: 02-16-2006, 04:54 PM -
FS: Volant CAI
By Tman in forum Parts For Sale / TradeReplies: 4Last Post: 11-07-2005, 01:22 PM
