    Junior Member The Popo's Avatar
    Mar 2009
    West Palm Beach, FL
    Blue
    2005 Pontiac GTO
    Dip stick problem!
    Has anyone with a supercharged goat have a problem with the dip stick popping out and spewing oil into the engine compartment? This has happened to me four times now and it's pissing me off!
    Junior Member scauffiel's Avatar
    Chesapeake, VA
    Carousel Red
    2005 Pontiac GTO
    Double-check your PCV setup; you're getting a pressurized crankcase. The pressure is building up and it's finding it's way out through the weakest spot - your dipstick.
    S.
    [email protected] my first gto's Avatar
    Flemington, NJ www.Rocksandracingllc.com
    Gray
    2005 GTO
    Quote Originally Posted by The Popo View Post
    Thats NOT a good Thing at all. You need to look in to a catch can with a open breather on it...
    I worked on an LS2 a week or so ago that the dipstick was extremely loose on. It was almost like the o-ring was worn down or something. Is yours very loose to begin with or does it fit in the tube snug?
    Mar 2009
    West Palm Beach, FL
    Blue
    2005 Pontiac GTO
    I replaced the ring and it still soes it. I think the pressureized crank case is the issue. I need to get it fixed.
    Thanks for the replies. BTW, what's a catch can?
    09 G8 GT
    http://www.ls1.com/forums/showthread.php?t=81389
    Basically it lets the oil from the PCV system drip into an aluminum can, instead of being re-circulated into your intake. Read at least the first post~long but GOOD thread; I'm N/A but may still do this in the future.
    Member The Silver Goat's Avatar
    Dearborn Michigan
    Qucik Silver Metalic
    2004 GTO - M6
  1. Ban stick?
    By ARM5280 in forum Almost Anything Goes
    Last Post: 07-07-2009, 06:52 AM
  2. 04 C5 A4 vs 09 350Z stick vz 370Z stick
    By Danger731 in forum Kill Stories
    Last Post: 03-27-2009, 03:03 PM
  3. Dip stick
    By wnmech in forum General Help
    Last Post: 11-30-2008, 01:45 PM
  4. New Stick
    By Retired Cop in forum Firebird / WS6
    Last Post: 10-23-2008, 07:07 PM
  5. Pro 5.0 w/Lou's stick
    By spdrsr1 in forum Parts For Sale / Trade
    Last Post: 06-06-2006, 08:56 PM
