Results 1 to 15 of 15
    Junior Member CPACOOLTA's Avatar
    Jul 2009
    Fairmont, NC
    1999 Trans Am WS6
    Talking Supercharger and Turbo
    Is there anyway possible to do both on a street car.
    Military Muscle :usa: MYSCZ06's Avatar
    Columbia,SC
    Millienum Yellow
    2003 Corvette Z06
    sure is...
    Jul 2009
    Fairmont, NC
    1999 Trans Am WS6
    Cool reply for supercharger and turbo
    explain how and how much horse power will it add?
    Member El Toro Loco's Avatar
    Harlingen, tx
    pewter
    2001 Trans AM WS6
    that should be an insane amount of power
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    ive heard of this idea, but with one turbo forcefeeding another to reduce lag.
    but yeah, just have a roots mount, and maybe remote turbos and it should fit just fine
    have the hot side run out back, hi the turbo, then have your piping run back up, intercooled, then the cold air fed into your roots mount.....the only thing is that you can only run so many pounds....youd need some insanely high flowing heads to make it worth it
    Jul 2009
    Fairmont, NC
    1999 Trans Am WS6
    Thumbs up
    what kinda heads do you recamend
    Pittsburgh
    2008 Hummer H3
    Feb 2008
    NEW JERSEY
    PEWTER
    2001 TRANS AM WS6
    look for stuff on a twin turbo supercharged malibu and look for info on the same set up but in a pontiac 1000 some guy built both cars back in the 80's
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Member 6.0LiterImportEater's Avatar
    Frederick, MD
    Phantom Black Metallic
    2006 Pontiac GTO
    It has been done many times.
    It doesn't quadruple power or nothing either. Don't be silly...
    Its advantage is mostly get the area under the curve at all times. Constant power through the rpm range.
    The supercharger is used up front since no lag exists. We all know the downfall of a supercharger is it robs power from the engine just to work. Thats where the turbos come in. Once they spool and reach desired psi the supercharger is cut from the equation. The turbos take it the rest of the way........or atleast til you shift and the whole process starts again.
    The disadvantage is the extra weight and cost. Thats why you don't see it at the strip everywhere. If you set-up either a supercharger or turbocharger system properly it will be just as effective.
    Since this was a ridiculous question can this thread be locked?
    Feb 2008
    NEW JERSEY
    PEWTER
    2001 TRANS AM WS6
    do a search for double blown gto judge
    2000 SS Black M6
    Quote Originally Posted by DIRTY JERZY View Post
    Yeah i think ive seen that....its a roots mount strapped on top of another roots
    Manhattan Trans Am SHovV's Avatar
    May 2008
    Tx
    Medium Blue Metallic
    '99 T/A-7.0L-6spd
    its possible. its expensive. i think hellion does it to mustangs. TT a super for 1k plus @ the wheels
    Bawlz Deep andrew rs's Avatar
    gold
    2000 honder accord
    its called compound boost, and the most efficiant way to do it is get a twin screw supercharger that is sized slightly smaller than you would buy normally, then get a large turbo or two large turbos that are sized slightly larger than you would normally have and once the twin screws efficiancy is on the decline then you have the turbos spooled up and they kindof take over, but still blow through the supercharger... get it? its all about the efficiancy of one and once that runs out the other takes over.
    Jul 2009
    Fairmont, NC
    1999 Trans Am WS6
    Cool
    thanks guys always wondered about if it could be done. Like yall said its gonna take alotta doe so might not do it anytime soon
  1. supercharger or turbo
    By pipes_ta in forum Forced Induction
    Last Post: 11-17-2009, 02:34 PM
  2. turbo vs supercharger ?
    By TA421 in forum General Help
    Last Post: 04-05-2008, 12:53 AM
  3. Question: turbo vs supercharger
    By SSMOKEshow in forum Forced Induction
    Last Post: 02-17-2008, 08:59 AM
  4. Supercharger or Turbo? What do you have/like
    By fastfirebird2002 in forum Forced Induction
    Last Post: 01-27-2008, 11:58 PM
  5. A4- supercharger or turbo?
    By socialdbob in forum Forced Induction
    Last Post: 12-21-2006, 07:31 PM
