Results 1 to 13 of 13
Thread: Starting after storing
07-19-2009, 07:45 PM #1
I try to drive the bird once a week. Sometimes it's more like once every two weeks. For some reason when I fire it up after a week or two of sitting, it won't idle, then dies. But when I start it the second time it starts right up.
Am I doing something wrong???Last edited by 1TA LS1; 07-19-2009 at 09:34 PM.
01 TA WS6: Volant CAI, custom ram-air baffle mod, custom borla, BMR-(SFC, LCA, LCA reloc, PH rod,TQ Arm), UMI swaybars, Eibach + Bilsteins, TTM Anth, SS brakelines, 160 deg therm, 3.73 gears, Yank 3400 stall, Yank Crsmbr, Hayden 24k, Trans Go shiftkit, ported TB + MAF...soon to be cam/heads
07-21-2009, 03:25 PM #2
Are you turning the ignition to "on", waiting until the pump stops and the chime stops before starting?
07-21-2009, 07:47 PM #3
07-21-2009, 08:31 PM #4
07-21-2009, 10:49 PM #5
07-22-2009, 02:10 AM #6
- Mar 2009
- Kansas CIty MO
cutting power to the computer resets it, so your car has to re-learn the air/fuel curve every time you are starting it.
07-22-2009, 03:09 AM #7
When the battery gets unhooked the first restart will be very weak, it may even die. Airflow learning is slower than fuel, and may take 25-35 miles of driving before fully learned back out.
07-22-2009, 04:10 AM #8
- Nov 2006
- Indianapolis
Yep, the PCM has to relearn how to idle the car. That's why your car has issues sometimes. If it only sits 2-3 weeks, no need to disconnect the battery. More than a month tho, it's a good idea to disconnect but not really mandatory.
07-22-2009, 04:27 AM #9
Is it bad for the engine when it does this? And does this affect my tune or will it just take a moment to reset?
07-22-2009, 04:09 PM #10
- Nov 2006
- Indianapolis
Shouldn't affect any tune. Not really bad for the engine, but if you don't need to disconnect the battery, don't do it. Like I said, unless it will sit for more than 4-5 weeks, there really is no need to disconnect the battery. If you are that concerned about battery life, it would be better to get a "battery tender" charger, you can leave it connected all the time and it will only do a trickle charge on the battery when/if it is needed.
07-27-2009, 08:37 PM #11
I am going to look into the battery tender. Someone had mentioned it to me before. I was only concerned about battery life cause my old battery died and I replaced it with a Optima battery. Thanks for the help and info all!
07-28-2009, 02:43 AM #12
08-05-2009, 05:26 PM #13
- Apr 2008
- illinois
red- 2001 Pontiac Trans Am
Just got a tune for my MS3 and battery went dead one month after. Put a new battery in and since it resets the computer the car will not idle and now i guess i will have to take it back to the damn shop!
Question: What do you do when storing your car (in the garage)?
By KMdef9 in forum Firebird / WS6Replies: 24Last Post: 11-05-2010, 06:11 PM -
who is storing their cars
By 1MileCrash in forum Camaro / SSReplies: 81Last Post: 10-22-2009, 03:43 PM -
Question: Help storing my car.....
By clg82 in forum Firebird / WS6Replies: 7Last Post: 07-06-2008, 01:13 PM -
Need some help on storing car 4 winter
By lvbroham1 in forum General HelpReplies: 4Last Post: 12-21-2007, 07:35 AM -
got a few ?'s about storing for the winter...
By bgable in forum Firebird / WS6Replies: 25Last Post: 10-18-2007, 04:57 PM
