Results 1 to 17 of 17
    Member DemonSpeed's Avatar
    Virginia
    Pewter Metallic
    1999 Trans Am
    fuel pump issues
    So for a while now ive noticed after long trips that there is a whining noise coming from the back of my car. Kind of high pitched like an electrical motor, figured it was the fuel pump. Well its finally going i think, after a long trip (120 miles) when i dropped my friend off it died and would only run for a sec then die again. I let it sit for about 10 min and it started fine and i drove it for a couple of miles to walmart and when i was pulling in it died and i coasted into a space. I went in and was in for about 20 min came out and it started fine so figured i would try to make it home. Drove for about 10 miles turn onto another road and it dies, let it sit, drive, die. seems like the longer it sits the longer i can drive. Question is if its the fuel pump itself or another part of the system?
    LS6 Engine swap, Custom Predator Tune, Lid, SLP Cold Air, Ram Air H.O. Hood, Hooker Long Tubes, !Cats, 3" True Duals w/Dynomax Bullets, Performabuilt stage 2 w/3600 stall, B&M Trans. Cooler, Moser 12 Bolt w/ 3.73's
    Pics of my car
    http://community.webshots.com/user/demonspeed_ta
    Junior Member kirkjames90's Avatar
    Jul 2009
    North, Texas
    1999 Trans-Am
    check your fuel psi that will help you determine for sure mine never died but it would almost all the time turns out it was the Fuel Pressure Regulator a lil piece thats on the side of the fuel pump housing it wouldnt seal up properly
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    well price a fuel pump and be shocked at the sticker price so you mightwant to make sure that the fuel pump is the problem and not a bad relay or something stupid like that
    Pittsburgh
    2008 Hummer H3
    Just did my fuel pump in the 01 Camaro couple weeks ago. Same thing happened to the wife which resulted in a AAA flat bed bringing her home. It would start after it sat for a while them die too. Mainly because when gas is subjected to temp variations it will build pressure in any sealed container it sits in. Just like it does in a gas can with the breather closed. This presure will provide a minimum operating presure level for the injectors to fire/spray. But as you found out the presure does'nt last and a sick fuel pump wont keep up. My fuel pump just died. Turned the key off let it sit for a sec and then turned the key to the run possition. Listen..........Notta sound. Tried again nothing. Let it sit over one night and the next day the pump started up but sounded like it was not doing good. Fired it up ran fine soon as I gave it gas the pump sounded like it was choking and the motor began to "diesel" then died. 500 bucks for the new pump and 3 hrs start to finish dropping the tank (yay! fun fun). I'd be willing to bet it's the pump. I would change the fuel filter too. Maybe the fuel presure reg but I doubt it...
    verify pressure like these guys said and if it turns out to be a fuel pump replace it with a racetronix kit. Cheaper and better than OEM.
    Pittsburgh
    2008 Hummer H3
    That's a given proceedure in any presureized system.......
    Virginia
    Pewter Metallic
    1999 Trans Am
    I got in it today and let it idle for about 5-10 min then took it down the road for a couple of miles, no problems. Who knows if it would have lasted longer. what if the pressure reads fine then it does it again later? seemed to run fine at idle and fuel pump sounded good when i turned the key on, when its having issues it sounds really sick when i turn the key.
    Pittsburgh
    2008 Hummer H3
    I dunno. But one thing I would'nt do is drop the tank only to put the old pump back in. IMHO I'd pick up a pump,filter, and anything else you can think of to just simply update the fuel system. Especially if your mileage is high. Hell I'm in the mid 70k range and mine died. It's possible a pressure test would still determine if the pump is weak. It may be running @ minimal opperanting psi too. Wont know unless ya check. But I'm still leaning towards the pump IMO. In my case the pump was clearly not functioning correctly, and sometimes not @ all. It's a small motor in the pump that has a big job to do, weakest link in the system if you ask me.IMHO
    Jul 2009
    North, Texas
    1999 Trans-Am
    Quote Originally Posted by DemonSpeed View Post
    ur psi should be around 55 i believe?
    you should get the pressure checked first before we move on to if its only good sometimes
    find someone with a fuel pressure reader its as easy as checking tire pressure a local shop let me use theirs for free
    but i seriouly doubt ur psi is gonne be fine
    i went thru alot of crap with mine i replaced the fuelpump with a brand new racetronix and it still ran like crap later we found out the regulator was not sealing properly which cause pressure not to build up so i was driving around with 22-26psi for a couple days heres a pic of it circled in the red
    its a 40$ part they DO NOT sell this individually so u will have to ask for another i believe mine is from a 02-04 chevy truck but i am not sure as it was a year ago. I highly suggest if u replace the fuel pump you take this piece off and try to blow air through the lil valve and if u can very easlily its bad
    hope this helps im speaking from tons of wasted time and money with the same problem you are having
    Virginia
    Pewter Metallic
    1999 Trans Am
    ok thanks guys, ill check the pressure and post what i find
    pa
    You can buy it seperately as long as you know what to ask for. ask for the v6 3800 regulator...same thing.......but it mounts up at the rail and uses a vacuum hose. If you look closely at your ls1 regulator you will see it has a port for a hose and is the same regulator.
    Quote Originally Posted by 99RTA View Post
    I have a feeling you're talking about the piece between the rails.....that isn't a regulator. It's a pulse dampner to keep constant pressure on the passenger rail when the injectors fire.
    pa
    NO i'm talking about the fuel pressure regulator. On the v6 its located on the fuel rail....... its the same part that is located in the fuel bucket in the LS1. It is the correct regulator and in fact its the regulator gm uses on all its cars and trucks since 99.Most applications also use a vacuum hose to lower the pressure at high vacuum, the ls1 does not use the vacuuum hose BUT if you look close you will see the VAC port on the LS1 regulator.
    Both the v6 and ls1 have the "pulse damper" on the rail but the v6 also has the regulator mounted up there and uses a return line.
    AND the "pulse damper" or commonly called acumulator is to cushion and absorb the fluid HAMMERING effects the injectors cause as they open and close. As the injectors close the entire fuel system gets a JOLT of fluid pressure that acts like a hammer damaging certain parts of the fuel system like check valves, injector pintle seats etc. That "pulse damper" acumulator aborbs that schock wave.
    Virginia
    Pewter Metallic
    1999 Trans Am
    ok so i checked the pressure and its a constant 60. Let it idle for a while then took it down the road and drove it fairly hard, came back and checked the pressure and it was still a constant 60 It ran normal, I guess its only on long trips? If thats the case is it the pump? should I replace it?
    Jul 2009
    greensboro nc
    victory red
    99 ws6
    i def think it is the pump and i would replace it cause at my shop we work on rental trucks like u-haul and budget rental trucks and on 99 and up gm 25 and 3500s and savana vans the fuel pumps do this exact thing all the time after the trucks go on long trips the fuel pump heats up and starts to get louder and the finally it dies and then u let it cool off and it will work again until it heats up and dies again. so def change it! lol
    Jul 2009
    PA
    2000 SS Camaro
    I have a fuel pump issue also. At idle the fuel pressure was 55 PSI in the higher RPMs it dropped off to 30 PSI. Should these maintain a constant higher pressure through all of the RPM ranges?
    Virginia
    Pewter Metallic
    1999 Trans Am
    ok so finally have the money to order a fuel pump, going to get the racetronix. Do I need the wiring harness too or can I just use the stock wiring?
  1. Fuel Pump issues again.
    By SMWS6TA in forum General Help
    Last Post: 04-30-2016, 02:29 AM
  2. Fuel pump fuel guage issues on my '02 B4C
    By ANDYZ28 in forum Camaro / SS
    Last Post: 12-29-2014, 10:30 AM
  3. LS1 all yr fuel injectors, oe fuel rail, pump,more
    By Frost in forum Parts For Sale / Trade
    Last Post: 04-27-2009, 02:26 PM
  4. fuel pump issues
    By SuperStock in forum General Help
    Last Post: 08-12-2008, 01:01 PM
  5. Replies: 3
    Last Post: 10-02-2006, 06:23 PM
