Thread: HELP:bolt pattern,etc?
07-18-2009, 06:06 PM #1Member
- Jan 2007
- canada
black- 95 trans am
what is the bolt pattern for a 95 trans am please?....Im looking at a set of ruff racing wheels but the bolt pattern is 120mm and 45 offset/ thank you so much for all your help
07-19-2009, 05:00 AM #2
it is 5 x 4.75" or 120.65mm. the offset for fitment depends on the width of the wheel as well.
07-21-2009, 03:12 PM #3Awaiting Activation
- Michigan
Black- 2001 Camaro Z28 A4
I know that a lot of people have put the RUFF racing wheels with a 120mm bolt pattern on their cars with no problems. However, be aware that our vehicles are specifically engineered to use the 120.65mm bolt pattern. Using the 120mm could cause you some problems like bolts loosening or worse, lugs breaking. Personally, I don't think it's worth the risk.
07-29-2009, 05:20 AM #4Member
- Jan 2008
- CORUNNA
black- 2002 WS6
Ruff racing wheels are awesome!!
Question: Bolt Pattern
By amysboxers in forum Wheels and TiresReplies: 4Last Post: 02-25-2011, 11:04 AM -
need help with bolt pattern??
By jbigdawg79 in forum Wheels and TiresReplies: 1Last Post: 03-07-2010, 01:00 PM -
What is our bolt pattern?
By z28punk in forum Wheels and TiresReplies: 4Last Post: 02-10-2008, 08:10 PM -
BOLT PATTERN 98 z28
By LETHALxLS1 in forum Wheels and TiresReplies: 4Last Post: 02-11-2007, 08:24 PM -
what is the bolt pattern?
By RAWPWR3 in forum General HelpReplies: 2Last Post: 05-10-2006, 05:29 AM
