    ThA B@nD!T SteelCityTA's Avatar
    Pittsburgh
    Electric Blue Pearlcoat
    1995 Trans Am(LS1 Convert
    Reverse Lockout Solenoid Where can I get one?
    Fellas,
    I have check Advance, Napa, and PepBoys and they all say they dont have this? Do I have to get it from a GM dealer?
    1995 Trans Am: 6spd - Pacesetter LT's - LS1 Front Swap - SLP LS1 FlowPac CAI - MagnaMouth CatBack - De-Cat - Eibach ProKit - Bilsteins - HP Evo's - 3pt. Strut Tower Brace - 4.10 Gears - Spohn Adj. PH - B&M Ripper Shifter
    Member Frozen WS6's Avatar
    EagleRiver, Alaska
    RED, BLACK
    2001 WS6, 1998 TA
    Good question. I think mine just failed last night also. I have no lock out any more. I was going to go to the dealer. The gm service manual says you need a special socket. Is that true? Anyone?
    Member Rk ws6's Avatar
    Apr 2009
    Hagerstown, Maryland, United S
    2001 ws6
    is your guys reverse difficult to engage
    Pittsburgh
    Quote Originally Posted by Rk ws6 View Post
    Yes sir, It doesnt go in easy anymore...I have to push it iver then in with both hands...Checked the dealer its like $160 for the Solenoid! Damn
    EagleRiver, Alaska
    RED, BLACK
    2001 WS6, 1998 TA
    Mine is the opposite. It goes right in. I can't down shift from 6th to 5th or it maygo into reverse if I'm not paying attention. When the key is off mine won't go into reverse at all. Then if I turn the key on it goes right in.
    Pittsburgh
    Quote Originally Posted by Frozen WS6 View Post
    I am not sure I follow...if you are down shifting from 6th to 5th then there is no real chance of going into reverse...now vice versa I can see that...where you are going from 5th to 6th...I see that a case where you may throw it into reverse rather than 6th...
    metro Detroit area
    I think you may be confused. Reverse is next to 5th , not 6th. Therefore one CAN get reverse when they want 5th. Before you shell out $$$ for a new solenoid check the fuse that operates the solenoid. With the key on and the vehicle below 5mph, it SHOULD be easy to get reverse. Key off, its a two-hander. These conditions will tell you if the solenoid( wiring included) is working. If the fuse is good and you still require two hands with the key on & the car stopped, you need a solenoid. However check the fuse as it is VERY rare for these solenoids to go bad.
    Pittsburgh
    Quote Originally Posted by 30thbird View Post
    LOL my bad bro...that was the first thing I looked at this Monday morning...
    I was definatley confused...it always hard..So I think it may be the solenoid...I crushed the ground hog the other day and it was so bad I wanted to cry...I think that did something to it...But when I looked where it was located I was like NO WAY its to far up in there to get it so I dont know...
  1. Wtb reverse lockout soleniod for 6 speed t56
    By 9t8z28 in forum Parts Wanted / Trade
    Last Post: 07-07-2010, 09:57 AM
  2. Wanted:6 speed lockout solenoid.
    By fordwhupper in forum Parts Wanted / Trade
    Last Post: 01-31-2008, 10:15 AM
  3. 6-speed reverse lockout solenoid.
    Last Post: 12-16-2007, 04:30 AM
  4. Reverse lockout?
    By slade8200 in forum Manual Transmission
    Last Post: 04-03-2007, 03:38 AM
