    Senior Member Ramairgod84's Avatar
    Aug 2008
    peoria, az
    2001 WS6
    master cyl/slave cyl line HELP
    Hey all, I just had my master and slave cylinder replaced a few weeks ago, and they said i need the line that goes between the master and slave cyl. I just bought a new master n slave, although for some reason they didnt come with the line. Does anyone know where i can get just that line?
    🤔 11s. blackbirdbrain89's Avatar
    hagerstown, mercersburg
    black trans am
    2000
    you DO NOT NEED A NEW LINE..... drill mos is must the issue in the hole in the line it too small.. drill it out look it up using search
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Quote Originally Posted by blackbirdbrain89 View Post
    His line is leaking and chewed up..
    he needs a new line.
    Bump for info.
    Aug 2008
    peoria, az
    2001 WS6
    Need Master Cylinder line!!!
    Hey does anyone know where i can get the line that goes from the master cylinder to the slave? it normally comes with the master but the kind i got didnt have it. I need it asap because mine is leaking bad!! Help!!!
    wichita, ks
    99 camaro
    I had the same problem on my 99 SS. I replaced the master and slave cylinder with ram pieces and they did not come with the line. I was told by the dealer the only way to get the line is to buy a master cylinder but, you can order them through mcleod just call them and tell them your application. Through them its a bit pricey I think i paid like 80 bucks.
    Parma Heights, Ohio
    SOM
    99 Trans Am
    Quote Originally Posted by dickiesrecordings View Post
    +1 thats what i had to do. plus its already got high flow fittings so you dont need to do the drill mod
  1. clutch line from master to slave 98-02 fbody
    By robs98mysticZ in forum Parts Wanted / Trade
    Last Post: 10-12-2014, 07:19 AM
  2. Slave Cyl and Master
    By afattitude in forum Manual Transmission
    Last Post: 03-17-2009, 06:54 PM
  3. braded line from master to slave
    By vance-53 in forum Manual Transmission
    Last Post: 09-08-2008, 04:44 AM
  4. Replies: 0
    Last Post: 01-05-2007, 01:33 PM
  5. OKAY...slave or master??
    By matt89 in forum Manual Transmission
    Last Post: 01-13-2006, 12:22 PM
