Results 1 to 16 of 16
Thread: Why would this happen?
07-15-2009, 10:01 PM #1
Why would it crack this way?
07-15-2009, 10:04 PM #2
Bad luck, vibration or manufactor defect
07-16-2009, 04:09 PM #3
Missing the rubber in the socket, or binding it when tightening / loosening.
07-16-2009, 05:33 PM #4
07-16-2009, 06:32 PM #5
It might have been cracked before you got it. Brand new, it's hard to see it, until it gets dirty. Nothing your motor caused. That's the good thing !!!
07-16-2009, 06:38 PM #611 years of bangin gears
- Jan 2009
- North Jersey
May have been dropped at the parts store by an employee.
07-16-2009, 06:48 PM #7
No no guys, cuz when I first put em on the car was running great! And then one day it started acting funny and messing up and stuff.. so I checked my plugs and that one was cracked on piston #4 so I replaced it and my baby was back to normal. And it hasn't done it again, that happened about 4 months ago but I barely got around to posting it, I know I slacked it.
07-16-2009, 06:51 PM #811 years of bangin gears
- Jan 2009
- North Jersey
Could have been a defect in the ceramic and maybe the heat caused the crack to spread?
07-16-2009, 11:21 PM #9Impounded
- Oct 2007
- Beaver Dam KY
Ceramic heat cycled and cracked. It does happen often. Its just a defect.
Probably was dropped and the heat cycles caused it to split.
07-17-2009, 04:48 PM #10Senior Member
- Apr 2008
- Madison, WI
It may not even be a crack all the way through. It probablly carbon tracking. The spark jumps down the outside of the white insulator and etches a carbon track. Its caused by bad plug wires and other things. When ever you have a carbon tracked plug, you need to also change the plug wire on that cylinder because the wire will usually have a carbon track as well which will lead to the plug carbon tracking again.
07-17-2009, 05:01 PM #11
07-18-2009, 03:52 PM #12
07-18-2009, 07:31 PM #13
07-19-2009, 10:43 PM #14
07-20-2009, 07:09 PM #15
07-21-2009, 01:36 PM #16
I've always used tr-55's and it had never happened and I just changed the plug and wire and its been about 5 months now and its been good... I think it was just like manufacture defect
Has anyone had this happen?
By TA98 in forum General HelpReplies: 24Last Post: 12-05-2009, 09:46 PM -
How does this happen??? Again!
By FORD RECOVERY EXPERT in forum Almost Anything GoesReplies: 11Last Post: 10-31-2009, 09:14 AM -
Question: never had this happen before..
By Brad(WS/Z0.6) in forum Manual TransmissionReplies: 2Last Post: 10-03-2009, 02:25 PM -
Could this actually happen to us?
By Mr. Hyde in forum Political / Debate ForumReplies: 7Last Post: 05-28-2008, 06:49 AM -
this ever happen to anyone?
By badazta in forum Almost Anything GoesReplies: 20Last Post: 05-23-2007, 02:20 PM
