    How long will it take?
    How much time should I plan on when putting on LT headers and an 3" ORY for my 98' T/A?
    Any secrets and HELPFUL hints are welcome..
    lift and tools will not be a problem.
    Bump. No one? Really?
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Check the stickies. A good thread just was posted. A complete how-to.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    what type of long tubes ?
    judging that the car is cool and you have a sawzall...about 4 hours-6 ....i did it in my grand fathers garage with jacks...sawzalled that bitch y pipe ....dont even bother with trying to get the bolts off...just remove the coils!! and the wires and the plugs..remove the oil dip stick and the header bolts (a 10mm ratchet wrench will help on the rear header bolts) then your in the clear...try to get the headers as vertical as possible..didn't take that long at all.
    Shepherd, Michigan
    98' trans am
    oh and i almost forgot!!! start the car up and drive it a little open headers! this way you can make sure everything works and clearences are ok..before you bolt the rest of the exhaust on
    Pittsburgh
    2001 Camaro Z28
    i used a sawzall (that was a lifesaver) and a torch. for some reason i couldnt get the factory y pipe off of my catback and i didnt want to cut that obviously. i heated the shit out of it.
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    Member QKSLVR99's Avatar
    Abilene, TX
    1999 Trans Am
    start to finish on a lift 4 hours if everything goes easy... like stated above, factory y can be a pain and depending on what headers you buy.... some are harder then others to install
    Member 666ws6's Avatar
    Greenville, SC
    2000 Trans Am Ws6 #2946
    Garage floor and jack stands... 9 hours for me, but did sway bars too inbetween.
  1. how long will it last
    By timothyodell2525 in forum Drivetrain
    Last Post: 09-19-2011, 01:52 PM
  2. BBK Long-Tube Headers Install - Going Long
    Last Post: 09-09-2011, 07:30 PM
  3. dad had a saying..... (long)
    Last Post: 03-26-2010, 11:43 AM
  4. How long?
    By scheier in forum Request and Feedback
    Last Post: 01-05-2006, 04:22 PM
