    Jul 2009
    Arlington
    2000 SS Camaro
    Unhappy AC Assistance on 2000 SS
    I just had to replace my motor as it died at 86,000 miles. We have the engine running fairly well now but have had AC troubles as well. I have replaced the compressor, orific tube,condensor etc about 3 times. Finally discovered that that there is black gouey oil comming out of the system. It started to cool and then discovered that there was also a small leak . It then went back to blowing out hot air. I am getting really frustrated Anyone have any ideas.
    Member Sayed_000's Avatar
    Middle East - Bahrain
    Camaro 2000 SS M6
    could be a leak in the compressor?or in the AC housing ..
    Jul 2009
    Arlington
    2000 SS Camaro
    Thumbs up
    how do i flush the system to get the trash out of it? Do you know what all I would need to replace after i flush the system?
    Jul 2009
    Arlington
    2000 SS Camaro
    There is a one leak that we found. Do you know if we can flush the system ourselves? Or do I need to take it somewhere?
    Thanks
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    you can flush and recharge your self..but remember its wise to replace more then the compressor
    pa
    @st thing you need to do is to completely open the system and flush everything with ac flushing solvent. Then replace the dry-acumulator-hose assembly then fill and you should be ok. Charging a dirty system just won;'t work, the orifice tube is only .035 thous of an opening and clogs very easily.
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by 99RTA View Post
    that's what i meant i just didn't know all the things to replace
    Shepherd, Michigan
    98' trans am
    so your looking at 260+ for everything..granted you find a A/c compressor for 160ish
    Jul 2009
    Arlington
    2000 SS Camaro
    Thanks for all input I am looking at flushing the system and getting pricing for replacement parts. i need some luck that this will fix the problem.
  1. Help: Assistance please
    By Jvarela in forum General Help
    Last Post: 02-29-2012, 11:08 AM
  2. Help: Need tuner assistance
    By Handyman401 in forum Computer & Tuning
    Last Post: 10-08-2008, 01:09 PM
  3. i need some serious assistance
    By RyanoLS1on in forum Wheels and Tires
    Last Post: 09-16-2006, 12:32 AM
  4. Replies: 14
    Last Post: 08-13-2006, 12:44 AM
