Thread: Removing the door panels
07-10-2009, 11:29 AM #1Junior Member
- Jun 2009
- Canada, Ontario
Black- 1999 WS6
To replace panel clips, or not to replace door panel clips. Im about to remove the panels in order to fix the cracking issue with them but im afraid of them fitting like shit and being loose and flimsy after the install. Should I go to GM and buy new clips that hold them to the door, just to insure a solid fit? Im positive that the panels have not been removed before.
07-10-2009, 11:46 AM #2
There are no GM clips to retain it. It's all in the panel, ...
07-10-2009, 11:54 AM #3Junior Member
- Jun 2009
- Canada, Ontario
Black- 1999 WS6
I see. So there is nothing at all that needs replacing? I just dont wanna end up with flimsy door panels :S
07-10-2009, 12:00 PM #4
Na not a bit. The door holds the "fingers" that go back into the frame. It slides out and slides back in.
07-10-2009, 12:53 PM #5Junior Member
- Jun 2009
- Canada, Ontario
Black- 1999 WS6
Got ya. So are these fingers that are held by the panels the ones that may need replacing or are they good to re-use?
07-10-2009, 01:24 PM #6
No you don't replace them. They are the panel.
07-11-2009, 04:59 PM #7Custom Painter/Tech
- May 2009
- Plainwell, Mi
Flame Red / Orange Custom- 1998 Trans Am
Yeah when you remove the door pannel you have to pull up on it and you will see the "hooks" (or fingers) the stick out they go into the door its self and you can not remove them unless you cut them off of the panel but dont do that lol its bad. As long as you put all of the screws back in you wont have any problems with it being flimsy.
Ebony door panels,headlights,sail panels
By VENOMOUS in forum Parts For Sale / TradeReplies: 9Last Post: 02-02-2009, 07:30 AM -
Trade? Ebony Z28 door panels for ebony firebird panels, NJ
By ShadowHawk in forum Parts For Sale / TradeReplies: 2Last Post: 06-19-2007, 09:10 AM -
Removing rear seat speaker panels?
By JRB 9966 in forum Stereo and ElectronicsReplies: 9Last Post: 05-29-2007, 09:45 AM -
Will 99 WS6 Door Panels Fit a 99 SS?
By x10-wakerider in forum Appearance SectionReplies: 2Last Post: 01-12-2006, 08:03 AM -
Door Panels
By oneBADDz in forum Parts Wanted / TradeReplies: 2Last Post: 12-18-2005, 05:57 AM
