    indianapolis
    2004 Pontiac GTO
    Question what should i do??
    hi, i am a newbie, and i am not sure what to do. i have an 04 gto, as of this moment, i have a k&n cai, and predator tune. i just got a little bonus from work, and the tax check is in the mail. all in all i have about $3000 to spend including instalation. i just don't know where to start. what would you do? this will be the first round of many mods the future holds. also, can anyone recomend a performance shop to do the work in indianapolis or nearby. thanks,
    shaun
    txcosmos
    Guest
    Long tube headers, and a tune. Don't know if you are an m6 or A4. Ported throttle body good for a few more. Cat-back to make it sound good. Might be able to get a cam install with the headers, that will wake it up the most.
    Retired Outlaw Sum Bitch
    Yup...Cam/headers/tune=beast
    indianapolis
    2004 Pontiac GTO
    i forgot to mention A4, i was thinking long tubes and cat back for sure, any particular brand better than the other. this is my daily driver, and i don't want it to be too loud, but i want the power. there seem to be so many cams available, i don't want to go to high lift, due to the cold here in the midwest. any recomendations on a particular cam? what about nitrous? thanks, for the help!!
    Boosted Foolz
    Buffalo
    BlAcK
    1998 FiReBiRd FoRmUlA
    if u dont want it really loud u can go with high flow cats, or a quieter catback system, ie, not the loudmouth... do all teh good bolt ons, ported t/b, L/T headers, i think you have an x pipe?? , u already gotta ls6 intake, you could also get a underdrive pulley and descreen the maf (or get maf ends). You could also change ur gears if u dont mind a loss in MPG. as for long tube headers, i know for the ls1 fbodys QTP and KooKs are the best, ceramic coated Pacesetter's are the best *cheap* header, but basically what u'll want is a stainless steel header
    Quote Originally Posted by faceteddiamond
    An A4....then I change my recommendation...
    3200 Stall/Headers/Tune
    indianapolis
    2004 Pontiac GTO
    can i add the headers with oem catback, and what do you think of the stainless works off road L/T? do i really need the cats (no emissions in indiana)? do you think it needs to be dyno tuned, or can i just get a custom tune from runnin with the devil for my predator? have you seen the nx nitrous maf kit? is the maf too far away from the throttle body for a wet kit in that location. i am just worried about a backfire filling the intake tube with fuel???? should i even be worried about it?
    txcosmos
    Guest
    I wouldn't bother with a cat-back yet. they are overpriced for the GTO's and make them pretty damn loud with headers. They also seem to have drobe with an auto. A good cam with get you about 30, headers another 15, and another 15 from a tune. Not bad for the money.
    And yes, headers and cats will bolt right to the OEM cat-back. Taking off the cats does make a big difference with these cars. I would get a full blown tune, not from a handheld.
    StainlessScott
    Guest
    "Stainless Works" long tube headers & exhaust for the 04 GTO
    "Stainless Works" offers quite a few different exhaust kits for the 2004 GTO. All of the systems are 3.000" 304-stainless steel and include an X-pipe and polished tips along with all the necessary clamps & hangers to complete the installation. The systems bolt up to the factory flanges for ease of installation. Retail pricing for the “cat-back” exhaust systems range from $733.95 to $838.95. The "Stainless Works" 1.750” headers are available with either off-road lead pipes (no cats) or with high-flow "Random Tech" cats. Retail cost for the headers is $943.95 & $1363.95 respectively. Drop us an e-mail at [email protected] or call us at 1-800-878-3635 for further information.
    Thanks,
    Scott
    Stainless Works
    05yellowbeast
    Guest
    What ever mods you do I would get a professional Dyno tune if you really want to get the most RWHP out of your mods. Don't use the Handheld.
    Brooklyn
    Blavk
    2002 WS6
    If you are worry about noise skip the catback, I had an 04 with cam (918 springs), Dynatech LT and Corsa Catback with stock airbox and filter made 379hp and 350tq. I eventually went back to stock catback because the car was setting off alarms going doen the block. The cam was 225/225 .589/.589 on 114 lsa.
    Brooklyn
    Blavk
    2002 WS6
    LT cost around 1100, cam, spring and pushrod like 750. Installed and tuned would be around 3000 total
